Old 12-01-2017, 04:53 PM   #21
Broadway Joe's Avatar
I have a Wildwood 27RKSS which is identical to your Salem. I just looked under my trailer and there are two resetable circuit breakers next to the junction box.
Joe
2015 Wildwood 27RKSS (now sold)
2015 Silverado 2500HD Duramax
Broadway Joe is online now   Reply With Quote
Old 12-01-2017, 05:03 PM   #22
Hey Joe,
Thanks for the reply.
yes, I'm aware of the circuit breakers, tested voltages on both terminals and am getting 12+ volts on both sides of the breakers. . .
AZJARHEAD is offline   Reply With Quote
Old 12-03-2017, 03:44 PM   #23
Originally Posted by AZJARHEAD View Post
Hey Joe,
Hi Joe,
I checked the negative battery to the frame. All is tight. I tested the negative side with a # 12 wire as you suggested, got 0 volts. So I did the reverse with the wire on the + post, positive side of meter connected to the wire. Wa-la, 12 volts touching the white wire and the ground terminal with the - meter. That tells me that the open is on the + side, right?
Now what?
Dan
Old 12-03-2017, 04:02 PM   #24
Hi Joe,
Now what?
Dan
No, I'm wrong on the previous post. I DO have an open ground, right?
Old 12-12-2017, 06:17 PM   #25
Fixed the 12 volt lighting problem
Hi Folks,
Thanks for all of your suggestions during the past couple weeks. I'm the guy with the 12 volt lights, pump etc. that didn't work. After relentless testing, and checking the continuity of the mini breaker connected to the battery under the trailer, I decided to replace the breaker. It had checked out as being continuous, but I figured, what the heck, I'll change it out for a whopping $9.60 I have nothing to lose. WALA! Everything works now.
Just thought I'd let those that tried to help me out know. . .
AZJARHEAD
Old 12-12-2017, 06:22 PM   #26
Mr. Dan's Avatar
OP posted his solution in a new thread. See this ====> http://www.forestriverforums.com/for...em-149683.html.
Old 12-12-2017, 06:57 PM   #27
Thank you for posting the fix, great to hear
GMC Denali 2500HD 4x4
Columbus 381 FLC 2016
Flagstaff Ultralite 29 RLSS
2013 35 nights, 2014 105 nights, 2015 123 nights, 2016 18 nights 🙁
Mike ONeill is offline   Reply With Quote
Old 12-12-2017, 06:59 PM   #28
fonzie's Avatar
Here is original post:
http://www.forestriverforums.com/for...st-149051.html
Fonzie
Old 12-13-2017, 12:21 PM   #29
Thanks for posting what you found. It just shows that sometimes even though things test good, they can still be the problem.
Gotta go campin!
Old 12-13-2017, 01:17 PM   #30
bob213's Avatar
Thank you for posting the resolution to your problem. Wish more would do that. More vital info in your single post here than the 23 posts in your original problem post. Funny that you mentioned the breaker in your first post and that's what it ended up being.
Glad you got things fixed
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 12-13-2017, 01:29 PM   #31
wmtire's Avatar
The site team has moved the solution posts to this thread it pertained to in order to keep the continuity.
2011 Flagstaff 831 RLBSS
Old 12-13-2017, 02:40 PM   #32
dmchapman's Avatar
My 2¢...My trailer has a 30A inline fuse holder adjacent to the circuit breaker near the junction box on the frame. When I shorted something on the monitor panel this fuse blew. Until I changed the fuse I had voltage in the coach from the converter but not the battery.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
cat, light, pump
