Old 08-15-2016, 02:04 PM   #11
Showing my ignorance... You are correct. I changed the anode rod.
It's raining right now, so I'll check the heating element when it stops. Thanks!
Larry Tiner is offline   Reply With Quote
Old 08-15-2016, 02:31 PM   #12
bob213's Avatar
You will need an elec. element socket(wrench) available at home depot or lowes for about $5. They should have a compatible element also. Our Ace carries Camco elements.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 08-15-2016, 10:57 PM   #13
The electric side started working again, but for about 3-4 hours. Then, it threw the breaker (also the breaker at the campground). Very weird...
Still raining, so I've switched back to propane for now.
Old 08-16-2016, 09:59 AM   #14
Wolverine 1945's Avatar
Originally Posted by wmtire View Post
Larry, I have a feeling you replaced the anode rod, and not the electric heating element.
Great Catch wmtire !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-17-2016, 04:34 PM   #15
Okay, I got almost through putting in the heating element, and it started pouring rain again. I'll update once things will dry out a bit.
Old 08-17-2016, 04:53 PM   #16
wmtire's Avatar
Larry did your verify the element was bad beforehand?
2011 Flagstaff 831 RLBSS
Wanna know how I plan on cutting carbs next year?
With a pizza slicer.
Old 08-17-2016, 05:03 PM   #17
No, wmtire. This is what it looked like when I took it out. I don't have any of the gadgets to test out electric 'stuff'.Click image for larger version
Name:	ImageUploadedByForest River Forums1471467799.281666.jpg
Old 08-17-2016, 05:09 PM   #18
My eyes/memory aren't as good as they should be. Can't remember if this is how I unhooked the wires. Before I turn power back on, what do y'all think?Click image for larger version
Name:	ImageUploadedByForest River Forums1471468160.059935.jpg
Old 08-17-2016, 05:38 PM   #19
wmtire's Avatar
My eyes/memory aren't as good as they should be. Can't remember if this is how I unhooked the wires. Before I turn power back on, what do y'all think?Attachment 117600
Let me try to find another pic to compare. Larry, since you are using your phone to take pics, it's too easy not to use it to also take a pic of something before you mechanic on it, so you have a reference to go back on.
I've gotten to the point, where I use my phone to take all kind of pics, before I start doing mechanic work on stuff. Has saved my bacon many times.
Old 08-17-2016, 05:46 PM   #20
wmtire's Avatar
Here's one from the web, as yours seems to be the same wiring.
heater, water, water heater
