Old 08-15-2016, 10:57 AM   #1
No elec. water heater
Last spring, I burned my water heater element. I changed it out and refilled tank. When I turned elec. back on, it threw the breaker. I went ahead and changed the element again and turned electric back on. Nothing... I know the tank is full, and it works on propane. The breaker looks fine. I'm not sure how to check the fuse. Any leads, please?
Larry Tiner is offline   Reply With Quote
Old 08-15-2016, 11:03 AM   #2
wmtire's Avatar
Assuming you are talking about a Suburban brand water heater...A lot of times when you burn up the electric element, you also can burn up the fusible link on the hi-limit ECO/thermostat.
This is the part underneath the rubber covers that say reset. You have TWO of these, and the one on the left is to the electric heating element...while the one on the right is to the propane side
Here is a pic of the link being burned out, on the left..as you can see it visually as it goes from the top terminal to the bottom terminal. You'll have to replace it, if it's blown........ but you can also just push the reset button to see if the ECO has possibly tripped.
If you do have to replace, make sure you get the correct one to the 120 volt AC heating element.
This schematic shows how the single 120 volt AC hot wire is connected via the switch, thru the ECO/thermostat, then to the electric heating element.
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 08-15-2016, 11:40 AM   #3
Thank you for the tip.
This is what I found. Looks okay, I think. Pushed reset button, but didn't feel any 'give'.Click image for larger version
Name:	ImageUploadedByForest River Forums1471279202.440175.jpg
Old 08-15-2016, 11:42 AM   #4
Also, my element has no screws on end to connect to, and no wires either.
Old 08-15-2016, 11:47 AM   #5
That on/off switch --- is 'on' when the 'on' end is pushed in, or when it is out?
Old 08-15-2016, 11:51 AM   #6
wmtire's Avatar
Larry, I have a feeling you replaced the anode rod, and not the electric heating element.
Old 08-15-2016, 11:55 AM   #7
Left Coast
On is in...
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 08-15-2016, 11:55 AM   #8
wmtire's Avatar
Here is how to replace the electric heating element. It would make sense if you replaced the anode rod (which is a different thing), why the circuit breaker tripped as the electric element is still shorted since it has not been replaced.
Suburban water heater electric element R&R
Old 08-15-2016, 11:56 AM   #9
I agree.
An electric heating element can't heat unless connected by wires.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-15-2016, 12:02 PM   #10
wmtire's Avatar
Here is a pic with the electric element on the left removed (note the two wires that connect to it). You usually have to remove the gas flue in front of the access cover to the electric heating element to gain access to it. It's explained in the link I posted previously above this.
The anode rod, is also shown removed in the pic below, but it is the hole to the right. You can replace the sacrificial anode rod, without removing a cover or propane lines/etc.
This is the anode rod. The anode rod is a sacrificial part of the water heater that deteriorates instead of the steel tank rusting out. It is to be replaced periodically, as it wears out. You also remove the anode rod to drain the tank.
This is the electric heating element:
heater, water, water heater
