Old 05-27-2017, 12:45 AM   #1
No electric
We are at a Campground and all is well at the pedestal. However we are not getting anything working in trailer.
No electricity.
Any ideas?
Lukegsdaddy is offline   Reply With Quote
Old 05-27-2017, 12:47 AM   #2
SeaDog's Avatar
check the main breaker for your panel
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-27-2017, 12:48 AM   #3
All is well there.
Old 05-27-2017, 01:07 AM   #4
Both my 40 amp fuses were blown.
Had to use 30 Amp for now.
Wonder why? The fuses on the panel.are not marked.
Old 05-27-2017, 01:31 AM   #5
40 amp fuses blown
The reverse polarity 40 amp.fuses blown.
Battery hooked up correctly.
Any idea why these blown?
Old 05-27-2017, 03:30 AM   #6
bikendan's Avatar
Usually the 40 amp fuses blow because the battery was hooked up backwards.
Equalizer WDH
Old 05-27-2017, 04:09 AM   #7
Iwannacamp's Avatar
I think the 40's are reverse polarity fuses normally. Has anyone had the battery off...or maybe hooked booster cables or an outside charger to it?
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 05-27-2017, 05:16 AM   #8
wmtire's Avatar
Have you connected or disconnected the battery lately?
The wiring colors on RV's can be confusing, especially if you have black and white leads instead of black/red.
If black and white leads, they are usually wired like your house is and the black is the POSITIVE wire while the white is the negative. This gets many members sometimes.
You may need to trace that white wire if applicable to your RV, and see if it's going to a ground or similar.
Now if you have red/black leads, then most likely it's wired like an automobile and your red is the POSITIVE, while the black is the negative.
They couldn't just make it simple. On my Flagstaff with black/white leads, the black is the Positive.
These threads may help:
Avenger Circuit Breaker
No 12 volt or hvac
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 05-27-2017, 07:43 AM   #9
A32Deuce's Avatar
Maybe you took a surge. Check your transfer switch if you have one.
A32Deuce is online now   Reply With Quote
Old 05-27-2017, 08:15 AM   #10
crunchman12001's Avatar
Did you get an error code on your Progressive industries EMS?
2015 F-250 FX4
electric, fuse
