Old 04-15-2016, 11:45 AM   #1
No Gen power
I have an 2014 XLR Hyprelite 29HFS with gen prep. I recently purchased an Onan and installed it. Pretty straight forward with the gen prep.
Generator starts and runs fine getting power to the transfer switch but no power to the trailer. Shore power and battery power work fine.
Is this an indication that the transfer switch is bad? Or something else?
2014 XLR Hyperlite 29HFS
TV 2014 Ram 2500 CTD
FlyinTA is offline   Reply With Quote
Old 04-15-2016, 12:05 PM   #2
B and B's Avatar
There must be way or means for the transfer switch to switch to generator. Maybe a control lead is missing to accomplish this. Normally Generator power will transfer the switch. This could be 12 or just 110 from the generator itself to engage the relay. Model # of transfer switch might help.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-15-2016, 12:19 PM   #3
hammer55's Avatar
usually double contact relay, need power from the gen through the contact of the normal power relay, you need a contact to hold out normal power when gen is on and vissa versa, or you can do it manually
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 04-15-2016, 12:23 PM   #4
Progressive dynamics
Model# PD5110610V
I was in there with a tester and was getting generator voltage to both sides of the switch.
I have seen so posts able these switches sticking and to tap them with something to knock them loose. It has been in the camper for a couple of years with no use. Wondering if that could be the problem
Old 04-15-2016, 01:21 PM   #5
hammer55's Avatar
yes could be rusted, might need to pull apart and cleaned, but if you have gen power to both sides (if that is what you are saying) it must be something to do with the power not getting to the panel
Model# PD5110610V
Mark & Annie
power
