Old 08-06-2012, 04:44 PM   #1
no light in bathroom 2006 surveyor (Solved)
light works but no power
frankc is offline   Reply With Quote
Old 08-06-2012, 05:13 PM   #2
Hello, and to the forums. As for your problem, need a little more info. How do you know that light works if you have no power? What have you tested and how? Do you have and know how to use a voltmeter?.
Sorry for all the questions, but no one can answer your question at this time. You will have to be the worker, and people here will tell you what to check and how, so if you have checked some things, please post it, so we don't start on the bottom floor and you already on the 5th floor. Help will come.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-07-2012, 06:17 AM   #3
checked light on another dc source,used test lite wires
Old 08-07-2012, 07:06 AM   #4
Herk7769's Avatar
Frank,
Are you talking about no power to the AC duplex outlets?
They are GFCI protected and the is a reset button in the middle of the outlet.
Lou
If you are talking about the wall switch light not lighting the DC lights, each light has its own on/off switch IN ADDITION to the wall switch.
HAM CALLSIGN - KC3FFW
Old 08-07-2012, 08:58 AM   #5
Originally Posted by herk7769 View Post
Frank,
Lou
no,the dc lite above vanity
Old 08-07-2012, 11:40 AM   #6
Fire Instructor's Avatar
My DC bath ceiling lights are dual-switched, and both switches have to be on. There is a switch on the light, and an unmarked wall switch by the entry door frame.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-07-2012, 04:25 PM   #7
Herk7769's Avatar
There should be a switch in the center of the light bar.
There is one there in my camper.
Old 08-07-2012, 09:45 PM   #8
thanks to everyone for your input, first time owning a travel trailer, didn't notice wall switch problem solved,thanks again.
