Old 11-03-2015, 04:41 PM   #11
wmtire's Avatar
Originally Posted by trailerdog View Post
I don't know where the converter is located on my camper. I will contact my electrician to see how he hooked it up.
Does your RV's power cord have 4 prongs on the end of it, or only three?
I would assume your RV is a 30 amp variety, but want to confirm.
Can you tell us, what exactly you are plugged into?
Can you, or are comfortable with using an electrical multimeter?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-03-2015, 05:21 PM   #12
Following
Old 11-04-2015, 11:43 AM   #13
Originally Posted by Bama Rambler View Post
There are a few things that can prevent you from getting 12 volt power through out the RV. The most common would be the main fuse blown. Have you checked all the fuses in the converter?
It would also be helpful if you could tell us the make of the converter.
Often there is also an inline fuse with-in a couple of feet of the battery. It could be blown causing everything to be dead.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 11-04-2015, 12:06 PM   #14
Something similar happened to me. All my 120 v appliances were working, none of the 12 v items were working.
I checked all the fuses. They were all good.
I went to a CW and they found that I had pinched the umbilical cord and shorted out the 30 amp Main fuse located under the front of the trailer. The battery was fully charged via my SUV.
Just a thought.
johng4706 is offline   Reply With Quote
Old 11-04-2015, 12:52 PM   #15
Just a thought.
That is the fuse I mentioned above. It is often overlooked, many may not even know it is there.
Jim
George Bernard Shaw
Old 11-04-2015, 12:57 PM   #16
I have never seen or heard of a main fuse at the battery. Anyone know if this is relevant on a Berkshire?
Old 11-04-2015, 01:00 PM   #17
TURBS's Avatar
"IF" the converter is working properly then this fuse being talked about is irrelevant regardless of good, bad or non existent battery.
Old 11-04-2015, 01:04 PM   #18
TURBS's Avatar
There are soooooooo many unknowns with this thread it's pointless to comment until op can provide more info.
1) does it have a microwave, and does it work?
2) does it have a tv, and does it work?
3) has the converter circuit breaker been checked?
4) is the converter working, and putting out voltage?
5) was the shore power pedestal wired for 220?
6) 30 or 50 amp service?
Old 11-04-2015, 01:54 PM   #19
1) does it have a microwave, and does it work? Not working
2) does it have a tv, and does it work? No TV installed
3) has the converter circuit breaker been checked? Don't know location of converter
4) is the converter working, and putting out voltage? Unable to check at this time
5) was the shore power pedestal wired for 220? The electrician wired it 220 by mistake, I put meter on it today and it showed 240 volts from rectp
6) 30 or 50 amp service? It is 30 amp service.
trailerdog is offline   Reply With Quote
Old 11-04-2015, 02:01 PM   #20
Pickin' & Campin'
Sorry... deleted... mis-read you have a 30 amp service.
Days Camped: '15=22 '16=46 '17=30 '18=4
light, power
