Old 11-04-2015, 06:28 PM   #31
Bluepill's Avatar
WFCO claims overvoltage protection on the 8955, but they may be talking something around 135 volts, not 250.
http://wfcoelectronics.com/wp-conten...015/05/7-1.pdf
Don't condemn the converter until you power it properly. Something on the main board may have fried, but the boards are replaceable. A local RV shop may have experience to test it for a reasonable fee.
WF-8955 | wfcoelectronics.com
If you do buy a new converter, you may want to upgrade to a 65 or 75 amp unit so that you can add more battery capacity at some time if you find your current set-up to be inadequate.
2008 Itasca Meridian 37H
Old 11-04-2015, 06:31 PM   #32
bikendan's Avatar
Originally Posted by TURBS View Post
All to many
Yep!
I wish you had come here or any other RV forum, before having your electrician do the work.
You could have saved yourself a lot of grief.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-04-2015, 11:24 PM   #33
wmtire's Avatar
Speaking of batteries, your RV battery is most likely depleted right now, as I explained in a previous post about your converter being fried and not able to recharge the battery.
As you are either awaiting repairs or a converter to be shipped, it is a good idea to recharge that battery. The longer you allow it to set in a discharged state (as it currently is now), the worse it is for the battery. You don't want to also ruin it and add more things to be replaced.
You can attach a battery charger to it (if you have one)... or remove the battery and take it to a battery store to have them recharge it for you. Many auto parts store that sell batteries will do this for you too.
One more caveat, to help out. If you do remove the battery, pay attention to which color cable goes where. Many RV's are wired with a black and white battery cable, in which the black wire goes to the positive and the white wire goes to the negative. It's more akin to the way a house is wired (wire color wise) than a automobile. It's too easy nowadays to just snap a pic of the setup with your cellphone, before removal, to aid in the reinstallation if you forget.
As you are a newer RV owner, may I also suggest when you get free time to peruse these links. It may help in your future experiences, and help in your understanding of your RV's electrical systems as well as the function of the converter. As I stated earlier, you are part of our group now, and we are going to help get you past all this, where you can really enjoy the camping experience. You have a great support group of friends here.
http://rvservices.koa.com/rvinformat...lectricity.asp
http://rvservices.koa.com/rvinformat...d-amp-draw.asp
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-05-2015, 06:10 AM   #34
TURBS's Avatar
Old 11-08-2015, 10:17 AM   #35
Originally Posted by johng4706 View Post
Sorry for your loss. You will be replacing several items. The FIRST thing on your replacement list should be a Progressive Industries Surge Protector. A VERY cheap investment considering what you'll be paying to replace your fried equipment. It will also protect you in the future when you're connecting in a campground from low voltage, incorrectly wired pedestals and/or lightning strikes.
This is very unfortunate but as stated, not all that uncommon. I strongly suggest you invest in a surge protector before fixing anything on yhe trailer. It most likely is too late to help you this time but you never know what you will run into in the future.
I would guess anything with an electronic control board cooked. I would not jump in and start replacing anything with out testing the item first. I would not count on it but you never know, you may be one of the lucky ones.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 11-10-2015, 04:10 AM   #36
MNtraveler's Avatar
Great info and links guys. Thanks! 👏
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-10-2015, 10:12 AM   #37
I ordered a new convertor board. Also Forest River sent me a list of all the appliances on my trailer so I can research replacement of repair manuals. Some have fuses that I can replace and get lucky. Waiting on new convertor board. Cost about $165.00. My electrician has owned up to the incorrect wiring and will help me with replacement cost. Life continues to be a learning experience!
trailerdog is offline   Reply With Quote
Old 11-10-2015, 10:16 AM   #38
Can I charge the battery without taking the cables off?
Old 11-10-2015, 10:29 AM   #39
wmtire's Avatar
Yes. Just make sure you put the chargers cables on the correct terminal + and -
As I pointed out earlier, many trailers have a black cable on the + terminal and a white cable on the - terminal of the battery. Your battery charger probably has a red cable for the + and a black cable for the - . You don't want to mix these up and put the black - cable from the battery charger onto the black + cable of the RV.
Old 11-10-2015, 11:11 AM   #40
NO, do not make that mistake! Double check things before making the finial connection. I think it is a stupid way of wiring but it is what it is. Here is a link to a cheap battery charger if you need one.
10/2/50 Amp 12V Manual Charger With Engine Start
I carry this with me just in case I need it. I also carry a cheap 750 watt inverter in my truck so I can power the charger using it if needed. I feel safer doing it this way than using jumper cables.
12V Power Inverter - 1500 Watts Max
HF would not be my first choice for tools if I was earning my living using them but for emergency use in the trailer they are fine.
Jim
George Bernard Shaw
light, power
