Originally Posted by Moorio
Everything was working then the lights went out but the microwave display was still lit up. The rear furnace was the first to go out then later that night the lights went out. When you start the engine the 12 volt system came back and when you shut the engine off the 12 volt system went away.
Sounds like your converter/charger is not working. If 12v was working and slowly went out, you were probably running off the coach batteries until they went dead. When you started the engine you were able to get power from the engine alternator.
Check your 120v circuit breakers and see if any are tripped. Look for one marked 'converter.'
