Old 02-28-2012, 12:39 PM   #1
No power from Generator
Hi and thanks in advance. Started and ran my generator as i do every other week and have no power to the coach. 1999 Georgetown with 5.5 Onan.runs fine.
Is there a fuse or a curcuit breaker on the genset?
With pluged in to 120 have power in the coach.
thanks again
rosiesrelics is offline   Reply With Quote
Old 02-28-2012, 12:45 PM   #2
TURBS's Avatar
you need to verify that there is no output from gen set first.
I recently replaced brushes and a reluctor ring on a onan gen set . 93 model year.
1 there was a houshold style breaker in the gen set compartment.
2 problably no other (fuses) inline
3 could be transfer switch (switches from shore to gen or back)
start at gen set and work your way back.
Old 02-28-2012, 01:42 PM   #3
Could be the transfer switch. I have had two of these go out. I hope for your sake it is just a breaker.
rkswyo is offline   Reply With Quote
Old 02-28-2012, 02:25 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
Name:	Onan Generator Diagram.jpg
This diagram should be typical of most Onan Generators. The Breakers are generally on the left side near the top. to the forums.
2007 Georgetown 370TS
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 02-28-2012, 02:38 PM   #5
As far as I know, (from older onan generators), if it starts and runs it is making power, just not making it to the panel. The famous "Onan will stay running as long as I hold the start switch down" is generally because the genny isn't producing power or a safety switch is open. If the genny starts and stays running its making power and safety switches are closed.
The reason they do this is when the start switch is held down it is bypassing the safeties in the genny so that it will start even if oil and such has low pressure(which it will till it starts), but if there is an issue with one of the safeties or its not making power it will shut down when start button is released. This is the short explanation.
So the fact that yours starts and runs just fine I would feel pretty confident in saying its a bad connection in wiring or the automatic transfer switch is bad, this is a common problem.
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
Acableguy06 is offline   Reply With Quote
Old 02-28-2012, 07:38 PM   #6
Thanks for all the replys..............will look in to this week.
