Old 05-01-2015, 10:31 PM   #1
No Power going into camper
We took the kids out for our first camping trip this weekend and ended up turning around and coming home, for some reason we have no power going into the camper when plugged in. We have it when hooked up to battery of course, we have checked all the fuses, the only thing we can figure out is when hooking the battery back up for the summer my husband hooked up the cables backwards, we knew because when putting the slide out, in was out and out was in........found out that the cables were backwards, my husband unplugged everything changed the cables around and then it all seemed to work fine, could something have happened when he did that and it messed up the electrical?
tcsorenson is offline   Reply With Quote
Old 05-01-2015, 10:33 PM   #2
jtstromsburg's Avatar
It's highly possible the converter (converts electricity from 120v to 12v) has a blown fuse.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-01-2015, 10:59 PM   #3
Is that something we can check? and if so how? or do we need to take it in and have it checked?
Old 05-02-2015, 07:08 AM   #4
HONDAMAN174's Avatar
Check your converter fuses. Typically there is a 40amp reverse polarity fuse for just that reason. It is sometimes hidden underneath the plastic face so you may have to trim some plastic to get to it. Read your fuse chart to find it
Just glad to get away
Old 05-02-2015, 08:18 AM   #5
TURBS's Avatar
Yep reverse polarity fuses.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 05-02-2015, 08:20 AM   #6
TURBS's Avatar
TURBS
Old 05-02-2015, 08:27 AM   #7
wmtire's Avatar
This thread may also help in locating/identifying the reverse polarity fuses and/or converter location.
No 12 volt or hvac
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-02-2015, 08:29 AM   #8
TURBS's Avatar
Hope this isn't the case but I have seen at least one converter fried when the battery was hooked up backwards.
TURBS
Old 05-02-2015, 10:45 AM   #9
Can't seem to find the link for our converter polarity fuses we have a 2014 Palimino Puma 32DBKS any help??? I google and find descriptions of our camper is all Husband just went out to get all the paperwork hoping to find something in that
Old 05-02-2015, 10:48 AM   #10
wmtire's Avatar
The thread I linked to in post 7 has a lot of information in it, as to where the polarity fuses may be located (either in the fuse panel..or on the face of the converter itself). It also has places your converter may be located, if the reverse polarity fuses do happen to be on the the converter itself.
I would suggest reading that whole thread as it may give you ideas what/where to look.
camper, power
