Old 04-24-2014, 09:47 AM   #51
Sounds like a new VOM hint for your birthday or Christmas is in order
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 04-24-2014, 10:27 AM   #52
BamaBob's Avatar
You may be interested in this kit -- I got it last year when I needed to replace a couple of GFI outlets in the house (and was NOT prepared to pay a electrician $200+ Parts to do it for me )
Extech MN24-KIT Electrical Test Kit - Multi Testers - Amazon.com
Cool part is this comes with it's own storage pouch. I have since transfered this kit from my garage toolbox to my 5er toolbox
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-26-2014, 05:41 PM   #53
LJ_Sha's Avatar
Apparently the problem is not fixed. Let Myrtle Beach at when I got home no power in 5th wheel. I noticed it when I attempted to put down my front jacks when hooked up to my truck. Only had enough power to get them down so I could pull out from under. Am I correct in saying I should have power when connected to 30 or 50 amp w/o using my batteries?
2015 Georgetown 351DS
LJ_Sha is offline   Reply With Quote
Old 04-26-2014, 05:57 PM   #54
Herk7769's Avatar
Try disconnecting the ground wire from the battery terminal and see if the converter powers up. Then check your resettable current limiters if "some" DC items work; but not your slides or landing gear.
If nothing DC works without the battery connected and it plugged in (AC items DO work), your converter could be bad, one of both ORANGE fuse(s) blown, or not powered by AC (check breakers and connection at breaker).
HAM CALLSIGN - KC3FFW
Old 04-26-2014, 06:11 PM   #55
LJ_Sha's Avatar
Since I had this issue at the campground I checked the fuses and breakers again here at home and all were fine. I had to connect a jump box up to the battery in order to get the slides out. I'll be checking the limiters and converter.
Old 04-27-2014, 11:44 AM   #56
LJ_Sha's Avatar
I disconnected the ground wires from the batteries and the converter did not start. I pulled the 2 fuses on the converter and when I placed them back in it started for a split second then stopped. If I tested the converter properly with my meter it only showed 6.82.
Old 04-27-2014, 11:50 AM   #57
raspivey's Avatar
It's sounding more and more like the converter is going.
Old 04-27-2014, 11:58 AM   #58
LJ_Sha's Avatar
That's what it looks like. I'm going to disconnect it and take it to a local RV store for testing just to be sure.
Old 04-27-2014, 06:38 PM   #59
Herk7769's Avatar
The full wave bridge in your converter has blown a diode. This can be repaired, but if it is beyond your expertise (as it is mine) a new converter (only) is not expensive.
With 1/2 wave rectification, you only get 1/2 the voltage.
http://www.amazon.com/dp/B004A30UHG/...SIN=B004A30UHG
Old 04-27-2014, 06:53 PM   #60
LJ_Sha's Avatar
Well beyond my expertise for sure. I'm already looking for a new one.
power
