Old 02-07-2015, 06:45 PM   #1
No power in most outlets
I turned the bedroom TV on this morning and 10 seconds later it went off. I noticed my laptop power light also went off. The laptop was plugged into a different outlet below the TV. I went into the bathroom and checked the GFCI outlet and it was tripped, but would't reset. I checked other outlets and noticed that 3 slave GFCI outlets in the kitchen were dead; 2 den outlets dead; ceiling fan in den is dead; outside GFCI slave dead; storage GFCI slave dead. I have another master GFCI outlet in the kitchen, which has no load, and it works.
This is a mystery as this rig is only 2 months old. It's a 2015 Cedar Creek 38RD 50 amp rig. I haven't had any problems until now. I called the dealer and spoke to a tech, who suggested that I trace the wires--really!
I pulled the GFCI outlet out of the bathroom and checked for power--none. No power coming to the plug. I checked the breakers and all were good. I checked the power on the breakers and all had power. I pulled two breakers for the outlets and checked the lines and all good and secure. I turned all breakers off and unplugged from the power pole. Reconnected and turned breakers back on and nothing changed. I looked through the access port to the rear of the breaker area and observed no junction boxes or loose wires.
I can't figure this out. Does anyone have a suggestion for a fix. Thanks in advance.
Sciatore12 is offline   Reply With Quote
Old 02-07-2015, 06:56 PM   #2
Mojojojo's Avatar
Not sure of the floor plan but or bunkhouse has 2 GFCI plugs one in the second bathroom, may have one outside or in an under compartment?
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-07-2015, 07:01 PM   #3
I've searched for an additional GFCI outlet and cannot find one. Just the one in the bathroom, which is not getting power, and the one in the kitchen, which is not feeding any other outlets and is working.
Old 02-07-2015, 07:04 PM   #4
asquared's Avatar
check your fuses.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-07-2015, 07:05 PM   #5
Mojojojo's Avatar
The kitchen GFCI may feed the other as a threw switch if either of ours pop they both go dead. Could be a bad switch?
Old 02-07-2015, 07:06 PM   #6
all fuses look good, but I thought they only were for 12 volt.
Old 02-07-2015, 07:09 PM   #7
asquared's Avatar
In our old tt we hooked the battery up back once. We blew 3 fuses. When that happened, we had power to some outlets and not others when plugged in to shore power. At first glance we thought all fuses looked ok but a second closer look comparing one fuse to another showed us the blown fuses.
2014 Sabre 34REQS-6
Old 02-07-2015, 07:22 PM   #8
Rrickim63's Avatar
Have you tried flipping all breakers on and off, just in case one has tripped and you didn't see it moved?
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 02-07-2015, 07:44 PM   #9
Yes, I have flipped all breakers and checked all fuses. All were ok.
Old 02-07-2015, 09:00 PM   #10
silver's Avatar
Two months old and everything running good, why assume problem is in trailer. Could you have lost a leg coming in from the campground? Have you a multimeter you could check source power source with? If no do you have enough cord to reach another power plug? I neighbors that you know works. If running through a pigtail remove it. Seems like to much is out to be a trailer problem. May also want to check your main breaker. Should be a two pole. Be careful with hot lines.
silver is offline   Reply With Quote
power, electrical
