Old 01-28-2015, 07:04 AM   #11
All wires seem to be good and in tact. Keep in mind this is happening in all 3 slides. Could it be something else? Or is there a switch or something I'm supposed to turn on? This is my first camper that has slides. Could I have missed something simple? Considering it has no electricity in all 3 slides and every where else the electricity works?
Crbaehr is offline   Reply With Quote
Old 01-28-2015, 05:55 PM   #12
ervinglobal's Avatar
Try to check all the breakers maybe some is off. Or all the wires are nit connected from the slides to the main panel. Is this unit is still under warranty?
ervinglobal is offline   Reply With Quote
Old 01-28-2015, 06:01 PM   #13
dan-nickie's Avatar
I don't think GFI outlets have been mentioned yet.
Have you located and checked all of those?
Each GFI will affect several outlets.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-29-2015, 08:36 AM   #14
rtc830
No power tp slides
Had same problem. Check to make sure that the connectors have not slipped off behind the switch or have shorted out. Pull panel and should be easy to check. Good luck
rtc830 is offline   Reply With Quote
power, slide, slide out
