Old 07-03-2016, 04:11 PM   #1
Makin' Life Simple
skisteveski's Avatar
No Power, new batteries just installed (parallel)
Ran old batteries completely down and they refused charge so purchased new ones today and install and hooked in parallel (pos to pos, neg to neg). All fuses intact. This is a 2013 Rockwood premier, A frame 122bh. What am I missing as all that was done was new batteries replaced old, yet nothing to the converter, no blown fuses, breakers all have been reset??
skisteveski is offline   Reply With Quote
Old 07-03-2016, 04:19 PM   #2
Flybob's Avatar
Check two large fuses in fuse panel ( 30-40A) they could have blown. Also check for resettable fuse on frame hear tongue. See photo below.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-03-2016, 05:15 PM   #3
Makin' Life Simple
The two larger fuses are not blown. How do I check the other inline fuse you referenced? With ohm meter or can I reset somehow? It looks just like your photo Click image for larger version
Name:	ImageUploadedByForest River Forums1467584075.616158.jpg
ID:	112968 but do I have to remove it to reset?
Old 07-03-2016, 05:18 PM   #4
AquaMan's Avatar
There will usually be a small black button on the side that will need pushed back in.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 07-03-2016, 05:21 PM   #5
Flybob's Avatar
The large inline should have a small button on the end to reset it. It may have a rubber cover on it ( usually red). See small black button on the right of the uncovered ones in the photo.
TST Tire Monitors
2 100W solar panels
Old 07-03-2016, 05:24 PM   #6
Makin' Life Simple
Black button located where?
Old 07-03-2016, 05:35 PM   #7
Mr. Dan's Avatar
Look at Flybob's pic in post #5. There is a small black button on the right side of these breakers.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-03-2016, 05:35 PM   #8
Flybob's Avatar
Small black button on right side of breakers in photo.
TST Tire Monitors
2 100W solar panels
Old 07-03-2016, 05:45 PM   #9
Makin' Life Simple
Gentlemen no button on this inline fuse. Ohm meter check indicates ok, reading zero, meaning no resistance like a blown fuse would have.
Old 07-03-2016, 07:23 PM   #10
Makin' Life Simple
Stupid here did't have neg to trailer . Thanks guys!
led, power, battery
