Old 07-09-2018, 01:24 PM   #1
No power to 110 outlets
I have a 2017 3170DS. There is no power to any of the 110 outlets. I have checked all fuses, breakers and the GFCI
GFCI has a green light on it, but it will not trip when the test button is pushed.
This is the same regardless of its run on generator or plugged into shore power. Any ideas of what the problem could be?
SSminnow is offline   Reply With Quote
Old 07-09-2018, 01:31 PM   #2
Manually flip the main breaker on and off. Breakers do wear out. If that does not work get out your meter and start with the source and work backward.
DYNAMAX 2016 FORCE HD
houstonstroker is online now   Reply With Quote
Old 07-09-2018, 01:34 PM   #3
Coach
No power even at the gfci with the green light?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-09-2018, 01:35 PM   #4
Bad part is that my friend has my RV and is not near me.
Old 07-09-2018, 01:36 PM   #5
Yes.. eventhough there is a green light. The plug does not work.
Old 07-09-2018, 01:52 PM   #6
Coach
Could the test button be stuck which wouldn't allow the gfci to reset? If that's would be the case, you probably want a new gfci. Don't know why it would give a green light though.
Old 07-09-2018, 01:53 PM   #7
Does your friend have a multimeter and know how to use it?
BTW.. what is a 3179DS?
I'm having problems locating that model?
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 07-09-2018, 01:58 PM   #8
Sorry..its 3170DS
Old 07-09-2018, 02:01 PM   #9
There is a mobile technician out there now. I would hope that he would have a multimeter, but he said he couldn't figure out the issue.
Old 07-09-2018, 02:05 PM   #10
Geez... sorry to hear that... not sure of his credentials if they are not able to figure it out being there??
We are simply suggesting (guessing) at what 'could' be wrong. Being hands on should provide way more answers than the mud we could throw at it hoping for it to stick.
power
