Old 08-12-2018, 09:59 AM   #1
No power to Fridge outlet
So I just brought my 2018 Wildcat 375mc home from the dealer and the fridge will not turn on. I checked the dedicated outlet for it and itís dead. This is a residential with an inverter. I am hooked up to 50 amp shore power. Anyone have any ideas ?
skicielinski is offline   Reply With Quote
Old 08-12-2018, 09:56 PM   #2
Duckogram's Avatar
Welcome to the FRF.
Juice goes through inverter to fridge. Check inverter on and breaker is not tripped. Some inverters are not pass through so you may have to have your 12v on as well.
If you post photos, it is easier to see exacty what you have rather then shots in the dark.
ILB
Old 08-13-2018, 09:33 AM   #3
Thank you for your response. I am currently at work. I spoke to the service man where I purchased the rv. He recommended that I check the fuses for the converter. So I will do that when I get home. I will keep you posted.
fridge, power
