Old 05-22-2018, 08:21 PM   #1
No Power to interior light swith...
So I have a new 5er, with slides and 4-5 light switches for different interior lights in the living room area. All of a sudden, one bank of 4 lights, controlled by 1 rocker switch, is not working. All other lights and switches are working. I ruled out that the switch is bad, changed it with another one and it works fine. I touched the two wires that connect to the switch for the light bank in question and the lights do not come on...thus no power in the wires going to the switch. Fuses in fuse panel are all fine. Also looked at wires under the slide to see if one got pinched and they look fine.
Any suggestions for what to look at next? Thanks in advance!
Pigpen29 is offline   Reply With Quote
Old 05-22-2018, 08:29 PM   #2
all the lights in my main cabin operated by the wall switch also have switches on the lights themselves. You didn't have a guest or someone come along and flip them all off not knowing there was a wall switch did you?
Kimber45 is offline   Reply With Quote
Old 05-22-2018, 08:38 PM   #3
rk06382's Avatar
Did you check the lights? There is a little switch on each light. Someone may have turned them off at the lights.
Get a 12v probe tester to check the power to the light switch.
Name:	12v probe tester.jpg
Amazon: OctagonStar 16012 Circuit Tester 6V/12V DC Systems Long Probe Continuity Test Light Car Voltage
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 600 Watts Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is offline   Reply With Quote
Old 05-24-2018, 04:00 PM   #4
Nope...they do not have switches on the individual lights.
Old 05-24-2018, 04:01 PM   #5
Attachment 172994
there are no switches on the individual lights and there is no power to the switch.
Old 05-24-2018, 05:57 PM   #6
rk06382's Avatar
'No power' to switch sounds like a fuse. With an pick probe you can test each fuse and even test to see if you have a good ground.
I googled '12v circuit tester how to use' and found this youtube:
Robert
2018 FR3 28DS
Old 05-30-2018, 10:05 PM   #7
Ok, found the problem...A crimped wire connection above the under belly had come apart! Great job factory electrician!!
Old 05-30-2018, 10:12 PM   #8
rk06382's Avatar
Glad you found it. Thanks for letting us know.
Now go camping!!
Robert
2018 FR3 28DS
Old 05-30-2018, 10:22 PM   #9
cavie's Avatar
You got a lot of nerve calling anybody that builds RV's an electrician!
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-31-2018, 08:06 PM   #10
Lol...yeah I know, I was slamming who ever it was that can't crimp two wires together!
light, power
