Old 06-24-2013, 04:21 PM   #1
No power to my electric stabilizers
As I loaded up last week the electric stabilizing jacks on my 831bhds worked fine. When we got to the campground neither the front or the rear switch worked ended up lowering them manually. The fuse box has a light that comes on when a fuse is blown and is showing nothing, does anyone know if there is a inline fuse somewhere I need to be looking for or anyone else run into this??
cerick2 is offline   Reply With Quote
Old 06-24-2013, 04:58 PM   #2
Were you hooked up to shore power when you raised them? When you lowered them if you were not connected to AC was your battery disconnect off by chance? That was what I found with my setup. If on AC it didin't matter if if the battery switch was off or not but if not on AC make sure your battery disconnect to the converter is on.
BMWPilot is offline   Reply With Quote
