Old 09-09-2013, 05:37 PM   #1
No power to outlets
Testing a TV connection, found I have no power at any of the outlets. I'm on battery power only, but nothing plugged in and everything powered off. Battery is showing full. Outlets worked fine over the weekend when running from shore power. Cannot reset the GFI outlet. Fuse box looks good - nothing tripped, no fuses blown. Any ideas would be greatly appreciated
Thanks,
Mark
Mark29 is offline   Reply With Quote
Old 09-09-2013, 05:43 PM   #2
Witch Doctor's Avatar
Being on battery only you will not get 110 volt unless you have an inverter to convert 12v to 110v. No outlets that are 110 v will work without being plugged in to 110V. You need to be on shore power to have A/C voltage.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-09-2013, 06:03 PM   #3
bikendan's Avatar
yep, the dealer should've explained that to you, during the PDI.
you can't run anything plugged into the outlets nor your a/c nor your microwave nor the electric side of the WH, if you don't have shore power or a generator.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-09-2013, 06:10 PM   #4
wmtire's Avatar
See if these help you understand the different systems in the RV:
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 09-09-2013, 06:21 PM   #5
D'oh, ok thanks. Should've occured to me 12v vs 110v.
power
