Old 12-07-2014, 01:35 PM   #1
no power to outlets
We have a 2010 puma 20qb new to us we have lights Ac/Heat but no power in the outlets and gfi will not reset.
laurieann is offline   Reply With Quote
Old 12-07-2014, 01:49 PM   #2
GFIs do go bad. I assumed you checked/reset the Breaker for the outlets.
saltyman is offline   Reply With Quote
Old 12-07-2014, 01:57 PM   #3
thanks going to replace the gfi
Old 12-07-2014, 09:18 PM   #4
Agree.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-08-2014, 01:01 PM   #5
A lot of times....
If a GFCI will not reset using the button on the device, it's either faulty or there is no power to the GFCI. Some time circuit breakers trip but they don't move the trip handle. What I would do is turn all the breakers off and then on again to make sure that they are reset and ready to send power to the GFCI. Then try the trip/reset button again.
Bill
2014 FR3 25DS (Bought 2-22-2014)
Spokane, WA
wjpelka is offline   Reply With Quote
Old 12-08-2014, 01:47 PM   #6
You could also put a voltmeter on the LINE side of the GFCI to be sure, however, if the reset button won't latch it sounds like the GFCI is bad.
2010 Chevy Suburban
Old 12-08-2014, 02:08 PM   #7
When replacing the GFI, there is a LOAD side and a LINE side. Remove the BAD GFI and make note of which wire are hooked to the LINE and LOAD side. Then leave the black and the white wires exposed in air and separated. Then with power on, check to see which is hot. That will be the LINE side. Kill power, install and check to see if that fixes your problem. Hope that helps and work safely...
Spokane, WA
Old 12-08-2014, 04:26 PM   #8
no power
Had the same issue with my brand new 2014 R-Pod after three months! I did the usual, checked the GFI which I found out does control 5 of my outlets, including my fridge! It wouldn't re-set so I replaced it and the new one wouldn't reset either! That told me there was a short in the circuitry somewhere so I took it in for service under warranty. Found out that I had a small leak under the sink which was previously repaired but the damage was done! There was a terminal coupling right under the sink because of my slider and the slow drip corroded the terminal to the point that it caused the GFI to trip. They eliminated the terminal entirely at the shop so even if there are future water issues it won't shut down half the trailer!
glfillion is offline   Reply With Quote
Old 12-08-2014, 04:38 PM   #9
Your situation may be different but I ran accross something similar to this in our motorhome. Thought issue was GFI rec but after testing line side connections I found no power going to it even after re setting breaker in MH panel . Turned out one of the legs of pedestal beaker was shot - only half my panel was energized. The half that had GFI breaker was dead You might want to put voltage tester accross line and load side of breaker to see if you're getting power to breaker
Nomore9-5 is offline   Reply With Quote
Old 12-08-2014, 04:41 PM   #10
PS Slight clarification - the breaker I'm referring to ( to test) is the one in your panel .
Old 12-08-2014, 04:54 PM   #11
Witch Doctor's Avatar
Did you discover this plugged in at home or at a CG? important!!!!!
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-09-2014, 04:27 PM   #12
Good Point...
I always start my troubleshooting at the power source. I agree that if it was okay at home but not at the campground, then the power at the pedestal is a good starting point. My RV is 30 amp/120, so I only have one hot leg to worry about. It's all or nothing in my RV...
Spokane, WA
power, electrical
