Old 08-09-2018, 07:12 PM   #1
No Power to slideouts and stabilizers
Newby with hemisphere 272rl.
TT is parked. Slideouts are extended. They will not slide in, stabilizers not working, and awning not working. Plugged in to 50 AMP shore power. Could it be a fuse or a switch that I am missing and if so where are those located for slideouts/awning/stabilizers?
Manateesue is offline   Reply With Quote
Old 08-10-2018, 08:33 AM   #2
Head Rambler
It could be a fuse or breaker. They're usually located near the battery, under the tongue or frame of the RV.
Old 08-10-2018, 08:54 AM   #3
cavie's Avatar
They are 12 volt powered. Is your battery turned ON? check the inline fuses near the battery. The converter should be able to operate them. Many do. Is the converter on.? Check the 2 40 amp reverpolirity fuses ( 40 amp )in the converter.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 08-10-2018, 08:57 AM   #4
Duckogram's Avatar
The 3 items you mentioned are often wired to the battery(s) seperate from the power distribution panel which contains your 120v breakers and 12v fuses. I suggest you follow your positive (red) battery cable to the terminal block and look for a small breaker with a tiny reset button.
Here is link to a photo of what you are looking for:
No battery power to anything
another link:
ILB
Old 08-10-2018, 01:17 PM   #5
Thank you for all the help. This forum is wonderful because of helpful people like you. I feel like I am armed with enough information to find the problem. I am not near my rv at present but feel like the battery switch to left of converter/inverter might be in the off position (red lever in storage compartment).
Old 08-10-2018, 09:38 PM   #6
Duckogram's Avatar
If thats the case there is a whole lot more not working than the items you listed.
ILB
power, slide, stabilizers
