Old 05-25-2016, 12:03 AM   #11
Originally Posted by Bluepill View Post
Some trailers have a circuit breaker in the red (positive) power line attached under the frame. If so, remove the red cover to find the reset button.
Thanks Bluepill. I am sure that is the problem, I just need to find that fuse! From the 7 pin plug to the trailer, I cannot find it. Once it goes into the trailer, all of the wiring is located below the floor, between the frame, which is covered on the bottom as well. Do I need to access this area you think? See picture. Thanks again.
mikeroho is offline   Reply With Quote
Old 05-25-2016, 08:13 AM   #12
Head Rambler
That cable should go into a junction box mounted in the front of the RV. That's where it's hooked to the RV wiring for lights and brakes.
It may be located behind a panel in the front storage area.
Gotta go campin!
Old 05-25-2016, 08:30 AM   #13
When on shore power, is there 12 volts on the TT pin that goes back to the TV (Pin 4)? The running lights and turn signals are fed separately from the house battery charge pin. I am sure that you already know this but thought I would ask. The answer is probably no and that indicates that something (fuse, breaker, etc) is open on that lead between the house DC panel and the TT cable.[IMG]http://i5.photobucket.com/albums/y20...ps702153a8.jpg[/IMG]
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-25-2016, 11:21 AM   #14
AKA: 'tiredTeacher
awellis3's Avatar
I agree. Mine on the Rockwood is on the frame about where your harness disappears. I agree with Bama, it has to be somewhere and you'd think it would be accessible.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-25-2016, 11:49 AM   #15
If you have a battery disconnect switch somewhere make sure it is turned on. Mine is in the storage compartment.
Tom
2014 Columbus 320RS
2015 Ram 3500 6.7L DRW
Amateur Radio Call: KQ5S
nineback is offline   Reply With Quote
Old 05-25-2016, 01:14 PM   #16
ScottBrownstein - I never did check if I have 12V going back to the TT plug. I understand the brake, turn and running lights work on a separate system. I just took the trailer back to storage for a couple weeks, I will check that when I get it back. Should I have 12V going back to the plug when connected to shore power?
Thanks for the input.
Old 05-25-2016, 01:16 PM   #17
Thanks everyone else for the input. I just took the trailer back to storage for a couple weeks. I had to get it off the roadway. When I get it back, I will double check the storage compartment again, if it is not there. I will attempt to take off the underside flooring/paneling on the frame to see if I can trace it.
Thanks again.
Old 05-25-2016, 01:25 PM   #18
raspivey's Avatar
You mentioned "when the battery is dead or disconnected". What is the voltage on the battery? The battery may be toast.
Old 05-25-2016, 01:54 PM   #19
Yep you should if there is a path for the TV to charge the TT batteries. Works both ways and I would expect that there isn't any voltage on pin 4 to ground. Just a thought. If there is voltage then your problem is not in the TT, but I bet there isn't and it is in the TT.
2015 335DS
Old 05-25-2016, 02:14 PM   #20
You will find your junction box just above the plastic belly panel where the cord goes through it. If you cannot easily pull down the panel. you can cut it with a razor knife and make a flap to open for access. Black Gorilla Tape works excellent to seal it back up. Do NOT use duct tape it wont hold. Breaker should be in the box.
hillsdaletc is offline   Reply With Quote
235rs, power, tow vehicle, trailer, truck
