Old 08-20-2018, 10:19 PM   #1
Exclamation No running lights on a 2012 Windjammer
We have no running lights on our 2012 Windjammer. Can not locate fuse panel either. Please help!
ambermichelleski is offline   Reply With Quote
Old 08-20-2018, 10:28 PM   #2
Splitshaft's Avatar
Welcome
That travel trailer likely does not have a fuse for running lights on the exterior of the trailer. Check the Tow vehicle. Just because the tow vehicle lights work, does not mean a fuse for the circuit going to the trailer plug in the back of the tow vehicle has not been burned. And if the fuse is burned, there is likely a short circuit causing the fuse to fail or the travel trailer is overloading the tow vehicle circuit for running lights. Alternately the tow vehicle and trailer plugs might not be making good contact between the two.
Splitshaft is offline   Reply With Quote
2012, light, windjammer
