Old 07-26-2013, 08:52 PM   #1
Exclamation No Trailer running, brake, or turn signals
We have no tail lights, brake lights or turn signals on Sunseeker 3050S, Traveling without owners manual. We assume it's a fuse, but we need help!
swendol is offline   Reply With Quote
Old 07-30-2013, 03:39 PM   #2
Batts-toy's Avatar
Wow pretty unusual to lose all those lights at one. They are fed by 3 different fuses (1 tail, 1 brakes, 1 for turn) makes me wonder if some wires got shorted to blow all of them? did you find fuses blown? Another possibility is a loose connection at the ground for these lights, if the fuses are good take the lens cover off the back lights and use a volt meter to test for voltage at the bulb you may have to remove the bulb and use a bare spot on the frame for testing ground (with lights turned on) if you have 12 voltage to the bulb and the bulb is good then you will need to track down the bad ground connection.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-30-2013, 03:42 PM   #3
Batts-toy's Avatar
Herk you may want move this to it's own thread.
Old 07-30-2013, 06:29 PM   #4
Herk7769's Avatar
The common wire to ALL the lights is the white ground wire.
An open there will cause all lights not to work.
Look in the metal junction box where the heavy black hookup wire enters for the white wire that goes from the plug to the camper's lights.
ID:	36553   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 07-30-2013, 10:29 PM   #5
Batts-toy's Avatar
Herk are you sure on this one, remember OP is asking about a MH not a TT?
Old 07-30-2013, 11:18 PM   #6
Herk7769's Avatar
There has to be commonality even with the motor home.
I doubt all the individual systems could fail at once.
Without a wiring diagram it is pure guesswork.
Money is still on a ground; just no idea where.
I think I have a MH diagram in the Herkbrary, but it is in the camper packed for Goshen. Will look tomorrow.
