No volts at trailer socket.
This is not strictly a Forest River issue, but I thought I would ask anyway. I wired lights for a trailer to tow behind my 1994 Grand Caravan, which has a seven-pin connector like the rest of our vehicles, including our Sun Seeker.
The wiring kit came with a four-pin coupler about three feet from one end of the cable. After wiring the trailer lights I took a seven-pin plug I had laying around and made the appropriate connections for running lights and brakes/turn signals.
Realizing that I had just made a seven- to four-pin converter, I unplugged the four-pin coupler and took it out to plug in to the back of my car to check that everything worked and went to "the right places." My reasoning was that I would not fry either the car wiring or the trailer wiring. Also, the car was parked at the curb and the trailer was in the garage.
After plugging-in my home-made adapter, I turned on the running lights and cycled the turn signals while I used a DVM to check for voltage that would go to the trailer. I got nothing on any connections. Then I went to our Jeep, which has a socket that I know works, because we pulled our cargo trailer with it a couple of weeks ago. Same result, no volts.
Any ideas? Do these things need a load to show voltage? I figured that there would be 12 volts on the pins when the lights are supposed to be lit.
I'm thinking of plugging the Caravan into the cargo trailer to see if the socket works.
Thanks in advance--
K-R.
2006 Sunseeker 3100SS - "Heart Of Gold"
2006 RAM 2500 Cummins - "The Beast"
2006 5th Wheel - "Graf Zeppelin"
