NOCO "Smart" charger or Battery Tender for truck that sits a lot
Which is best?
My TV often sits for weeks without being driven. When not towing and just "running around town" I drive my Volt and only buy gas once or twice per year (about 6 gallons each time into a 8-9 gallon tank). The constant sitting has taken a toll on it's battery and I recently had to replace a lot sooner than expected.
Have decided to purchase a battery maintainer and keep it connected when not using. Now for a decision. Battery Tender has been around for a long time but to me their product line appears quite "dated". From what I read they are basically a simple charger that eventually drops charging voltage to float voltage and then runs for a few days before a timer shuts it off. When load is applied or voltage drops below a given level the "Tender" then switches back on.
The NOCO line seems to be a little more current with more advanced charging/maintaining profiles. Their spec sheets show that they follow the same profile as the better converters in RV's, including a "desulfation" mode after a certain number of days of inactivity. A stage that appears to be lacking on the Battery Tender line.
My truck has a Group 27 battery with lots of Reserve Capacity but an unknown "Amp Hour" rating. I'm thinking something like a 1.5 amp max charge rate unit would be adequate as I doubt there will be any "heavy lifting" required to just keep the battery healthy.
What experience have people had with the NOCO? Is it as good as they claim? Or is it just the same as the Battery Tender in a fancier dress.
