Old 09-13-2013, 09:01 AM   #11
TURBS's Avatar
Originally Posted by Pat-n-Kat View Post
OK friends, this problem was due to a grave oversight on my part. I put a double pole breaker in my house so I dumped 220 on a 110 inverter. A/C and fridge are fine. I zapped the control panal on the microwave. My battery will no longer take a charge so I fried it as well. I will replace the battery to solve that of course. I don't suppose the inverter needs a good battery to work properly does it? A guy can dream right? Any way, I think I may get away with just a battery and inverter. Not to bad for such a bonehead mistake on my part. I truly appreciate all the advice and help on this issue.
Pat
You CANNOT run a wfco converter without a battery or with a bad battery.
Is your converter working?
Turbs
Old 09-13-2013, 09:04 AM   #12
TURBS's Avatar
Other things you should check.
Tv
Radio dvd combo
Water heater
Furnace
Converter
Old 09-13-2013, 02:40 PM   #13
Pat-n-Kat's Avatar
Turbs and Barry, the reason I say the battery isn't charging is I took it out and put my battery tender on it, it isn't excepting a charge. Will have it tested to be sure. TV was not hooked up and the water heater is fine but haven't checked the furnace.
Turbs, according to what your saying I will need to check/replace the battery first to know for sure. When hooked to tow power all 12v works fine. When I am hooked to shore power I have know 12v. But if I understand you right, I will need a good battery to know if the converter is working properly.
This will take a while since I have 13 members of her family here with us for a wedding and then the better half and I fly out Sunday for a little R&R on a big boat with many cold beverages. All of you have been very helpful. Will let you guys know how it is going when we get back.
Thanks,
Pat
2013 Wildwood X-Lite 261BHXL
2012 Ram 1500 QuadCab 4x4 with 5.7 Hemi
Pat-n-Kat is offline   Reply With Quote
Old 09-13-2013, 03:51 PM   #14
TURBS's Avatar
Thanks,
Pat
Pm sent.
Turbs
Old 09-13-2013, 04:55 PM   #15
Pat-n-Kat's Avatar
Got it
charging
