Old 09-05-2016, 12:49 PM   #1
hkreck's Avatar
Oil for the generator?
Hope everyone is having a great Labor day week end and hope no one has any issues. I'm looking at the type of oil used in a generator, I have a Cummins Oran RV QG 3600 LP. It's a propane generator and I haven't used it much but I did change the oil a little over a year ago. At that time because I live in Iowa and the temps can get down in the single digits, I put a 10W30 weight oil in it, which is recommended by Cummins. I am wondering now if a synthetic oil could be used? Any thoughts out here about this?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-06-2016, 11:49 AM   #2
Head Rambler
Cummins says in the manual that the use of synthetic oils is not recommended during the warranty period. I'd take that to mean that they don't recommend it at all, but once it's out of warranty, use what you want.
As clean as LP burns, I wouldn't worry about using a synthetic oil. A god high grade dino oil is all you need.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-06-2016, 11:54 AM   #3
ilmor's Avatar
I would not switch to synthetic if the specifications don't show it.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-06-2016, 12:04 PM   #4
VinceU's Avatar
X3
Old 09-06-2016, 12:08 PM   #5
hkreck's Avatar
I was just wondering about this because I know synthetic oil flows easier in cold weather than regular oil. So I was thinking it might be better during the winter, if I needed to use the generator even.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 09-06-2016, 12:59 PM   #6
NMWildcat's Avatar
I've always used synthetic in all my generators and lawn mowers. As long as the specs match the manufacturers recommendations, you should be good.
Scott and Liz - Southern NM
Old 09-06-2016, 03:46 PM   #7
Most of the time, when a manufacturer doesn't recommend a synthetic, it is because they do not have one in their brand. They like to sell their own branded products.
I have been using Amsoil Formula Four Stroke small engine oil in my generator, lawn mower and snow blower for years. All run like new.
AMSOIL Formula 4-Stroke Synthetic Small Engine Oil
Matt Smith
2016 Coachmen Prism 2150LE
Johnston, Iowa
capav8r is offline   Reply With Quote
Old 09-06-2016, 03:59 PM   #8
With a liquid fuel engine the fuel splashing around inside the cylinders tends to wash the oil off of the cylinder walls. Propane is a gas and doesn't do that therefor the propane engines last a long time. I doubt if you will ever wear out your generator.
larrysteimel is offline   Reply With Quote
Old 09-06-2016, 06:34 PM   #9
hkreck's Avatar
OK, I just got an email answer back from Cummins They stated that synthetic oil is OK to use in my generator. So I guess that takes care of that question. Thanks everyone for your response.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 09-06-2016, 11:24 PM   #10
syn oil
have a new MH with onan cummins and manual said not to use syn. oil during the break in period then it is okay as long as it meets specs. The syn. oil lubes too good to allow the piston rings to seat so they want you to use dino until the rings seat.
markb422 is offline   Reply With Quote
generator
