Old 09-18-2016, 09:12 AM   #11
Phat Phrog Stunt Crew
elind's Avatar
I tried running my AC on a 20 amp plug from my garage with the 30 amp cord and an adaptor. Later I found the wall outlet and adaptor burned. The weakest point couldn't handle the large draw and it didn't blow the breaker.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 09-18-2016, 01:52 PM   #12
Heck yes
Stevekbk is offline   Reply With Quote
Old 09-18-2016, 02:02 PM   #13
Evereddie's Avatar
Originally Posted by lugoismad View Post
I have not had any issue running my 13,500 BTU ac on my 15 amp circuit on a 100 foot extension cord.
You are playing with fire. You most likely are dramatically shortening the life of your compressor. I would at the very least check your voltage with a meter while it is running. Check back with that voltage reading.
There are 10 types of people in the world.
Those that know binary, and those that don't.
Evereddie is offline   Reply With Quote
Old 09-18-2016, 02:34 PM   #14
I concur. Be concerned if the voltage is below 110 volts under load. Be sure the extension is at least 12 guage.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab.
CedarCreekWoody is offline   Reply With Quote
Old 09-18-2016, 03:58 PM   #15
Threegaleh's Avatar
Mine and my neighbors blows if we plug it in and run air. I don't understand how you can.
Threegaleh is offline   Reply With Quote
Old 09-18-2016, 04:04 PM   #16
My garage was added to the house in the 70s, and has a 100 amp subpanel with 4 15 to 30 amp edison fuses. I use 20 amp fuses, but they are the slow-blow kind mind for circuits with refrigerators and stuff. So, that might be what it is.
lugoismad is online now   Reply With Quote
Old 09-18-2016, 04:14 PM   #17
Yet! Youroo!! You said 15A! Now it is a "Modified Circuit"?
Old 09-18-2016, 04:14 PM   #18
raspivey's Avatar
I had no problems doing this before I put in the 50A this year. Shorter, heavier extension cord and no problems. When I installed the EMS on this trailer, I ran my 15K unit plugged in the same way just to see what it was and it showed about 109 - 111V pulling around 13A. Specs on the AC I believe were 106 - 123V.
2012 Chevy Tahoe LTZ - HD tow package
Old 09-18-2016, 05:01 PM   #19
His might be a 20 amp breaker and not be aware of it. They are often used on circuits even though the outlet is a conventional 15 amp. Only way to tell is to check the breaker. But the same concern for voltage drop still exists.
Old 09-18-2016, 05:58 PM   #20
Sorry, I walked out to the garage and checked. I was wrong, it was 20 amp, not 15 amp time-delay fuses. LUGOISMAD!!!!!
Sorry I'm not perfect!
power
