Old 09-18-2016, 07:10 PM   #21
RV (Not so) Noob
Glindz233s's Avatar
OK for lights, fan, battery and fridge. Not mutch else. NO on the A/C.
Me, Wifey, Thing 1 & 2 plus Gracie the Shitzu rescue
FR Shamrock 233S 2015
2008 Tacoma Double Cab
Glindz233s is offline   Reply With Quote
Old 09-18-2016, 09:59 PM   #22
MainelyUS's Avatar
I had the same concerns with plugging in the Windjammer into a garage outlet....especially when the grandkids land and take over the TT. I discovered that the house elec panel had a couple of spare slots...had a electrician add a 30amp circuit and an outside rv elec box. Now I don't worry when the Windjammer is plugged in.
Happy Trails
2015 Windjammer 2618VS (Hibernating)
2016 Silverado 2500HD Z71 6.0L 4:10 gears w/max. tow package
Reese Strait-Line WD
MainelyUS is offline   Reply With Quote
Old 09-19-2016, 10:12 AM   #23
Vince and Charlette's Avatar
Did the same thing as "MainelyUS" showed on his post, but had enough extra amperage on my house to add a 30 and a 50 amp outlet. Yes, even on my own home, I use a surge protector for my 2015 GT 364TS.
Name:	30 & 50 Amp service.jpg
2015 GT 364TSF
Vince and Charlette is offline   Reply With Quote
Old 09-22-2016, 01:52 PM   #24
I tried my 15K on a 20amp 120v service through a normal household wall outlet with a 100 ft 15 amp cord to see the voltage drop. 115v with no load. 113v with hvac fan only. 101v with compressor and fan. Too low for me, I turned it off. Guessing a 20amp cord would probably result in less voltage drop.
Lamar is offline   Reply With Quote
Old 09-22-2016, 02:24 PM   #25
You do not want to run it on that cord! I use a 30 amp cord, same I use at campground. Voltage at home on 20 amp circuit only drops to 119 with compressor running (124 volt no load).
CedarCreekWoody is offline   Reply With Quote
Old 09-22-2016, 05:02 PM   #26
Thanks! Just ordered a 50' 30 amp ext cord. https://www.amazon.com/Camco-55197-P.../dp/B004809YBE
Old 09-22-2016, 05:06 PM   #27
raspivey's Avatar
Make sure you get a decent adapter and not one of those cheap ones. That'll be the weak link and the cause of some of those melted plug issues you sometimes hear about.
2012 Chevy Tahoe LTZ - HD tow package
Old 09-22-2016, 05:57 PM   #28
Evereddie's Avatar
And keep the connection clean with some electronic contacts cleaner.
Evereddie is offline   Reply With Quote
power
