09-17-2016, 08:19 PM
OK to use household power?
When I plug my fifth wheel into my household current (120v 15amp) will it charge my battery? I lease so I don't have the option to change the outlet in the garage. Thanks for the help.
[SIZE="3"]Kim & Katie Fay[
Hilton, NY
2022 Cherokee Alpha Wolf 28FK-L
2021 Ford f150 XLT, 5L, Garmin RV760MT
Travel Companions - Zoey and Zeus
09-17-2016, 08:22 PM
Definitely. I plug mine in to cool the fridge down before we load it for a trip.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Flagstaff Micro Lite 23lb
Tim & Tracy, Jennifer (20), Alyssa (15), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
09-17-2016, 08:33 PM
Yes , It should be fine just do not try to run the AC.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-17-2016, 08:36 PM
Yes you can use 15 amp service to charge your battery. When you first connect the 120 volt supply, the battery charger will usually draw the most current. After a few hours (as the battery becomes mostly charged), the current draw will decrease. I suggest not trying to run the fridge on 120 volts for those first few hours, because you may draw too much current for both it and the charger.
09-17-2016, 08:58 PM
neither the fridge or charging of batteries uses much power at all. Mine stays plugged in all camping season. Never draws more than 3 amps
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
09-17-2016, 09:02 PM
I have not had any issue running my 13,500 BTU ac on my 15 amp circuit on a 100 foot extension cord.
09-17-2016, 09:03 PM
Dazed & Confused
Yes, when plugged in with fridge running and converter keeping battery charged I see an average of 3 amps draw.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
09-18-2016, 07:55 AM
You will. It is hard on the compressor running low voltage
1966 Mustang GT
1986 Mustang SVO
09-18-2016, 07:59 AM
No doubt. Lots of voltage lost through that long of a small cord. Just because it's running now doesn't mean it's OK.
09-18-2016, 08:10 AM
One thing I have not seen mentioned is yes your house current will supply power to run the converter to charge the batteries provided your (if you have it) battery disconnect is in the connected position.
Retired Navy
2016 Flagstaff 26 FKWS
09-18-2016, 08:12 AM
Phat Phrog Stunt Crew
I tried running my AC on a 20 amp plug from my garage with the 30 amp cord and an adaptor. Later I found the wall outlet and adaptor burned. The weakest point couldn't handle the large draw and it didn't blow the breaker.
2014 Wildcat 327ck
09-18-2016, 12:52 PM
Heck yes
09-18-2016, 01:02 PM
You are playing with fire. You most likely are dramatically shortening the life of your compressor. I would at the very least check your voltage with a meter while it is running. Check back with that voltage reading.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
09-18-2016, 01:34 PM
I concur. Be concerned if the voltage is below 110 volts under load. Be sure the extension is at least 12 guage.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-18-2016, 02:58 PM
Mine and my neighbors blows if we plug it in and run air. I don't understand how you can.
09-18-2016, 03:04 PM
My garage was added to the house in the 70s, and has a 100 amp subpanel with 4 15 to 30 amp edison fuses. I use 20 amp fuses, but they are the slow-blow kind mind for circuits with refrigerators and stuff. So, that might be what it is.
09-18-2016, 03:14 PM
Yet! Youroo!! You said 15A! Now it is a "Modified Circuit"?
I had no problems doing this before I put in the 50A this year. Shorter, heavier extension cord and no problems. When I installed the EMS on this trailer, I ran my 15K unit plugged in the same way just to see what it was and it showed about 109 - 111V pulling around 13A. Specs on the AC I believe were 106 - 123V.
09-18-2016, 04:01 PM
His might be a 20 amp breaker and not be aware of it. They are often used on circuits even though the outlet is a conventional 15 amp. Only way to tell is to check the breaker. But the same concern for voltage drop still exists.
09-18-2016, 04:58 PM
Sorry, I walked out to the garage and checked. I was wrong, it was 20 amp, not 15 amp time-delay fuses. LUGOISMAD!!!!!
Sorry I'm not perfect!
