Old 09-17-2016, 09:19 PM   #1
fayliss's Avatar
OK to use household power?
When I plug my fifth wheel into my household current (120v 15amp) will it charge my battery? I lease so I don't have the option to change the outlet in the garage. Thanks for the help.
Fayliss
Hilton, NY
2016 Rockwood Ultra Lite 8286ws Fifth Wheel
2011 Silverado 2500 HD, Garmin RV760MT
6.6 Duramax Diesel, Allison Transmission
Travel Companions - Rocky and Emmy
fayliss is offline   Reply With Quote
Old 09-17-2016, 09:22 PM   #2
PSUFan1's Avatar
Definitely. I plug mine in to cool the fridge down before we load it for a trip.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Flagstaff Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 09-17-2016, 09:33 PM   #3
Oaklevel's Avatar
Yes , It should be fine just do not try to run the AC.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 09-17-2016, 09:36 PM   #4
Bluepill's Avatar
Yes you can use 15 amp service to charge your battery. When you first connect the 120 volt supply, the battery charger will usually draw the most current. After a few hours (as the battery becomes mostly charged), the current draw will decrease. I suggest not trying to run the fridge on 120 volts for those first few hours, because you may draw too much current for both it and the charger.
2008 Itasca Meridian 37H
Old 09-17-2016, 09:58 PM   #5
davel1971's Avatar
neither the fridge or charging of batteries uses much power at all. Mine stays plugged in all camping season. Never draws more than 3 amps
David & Lynn
Old 09-17-2016, 10:02 PM   #6
I have not had any issue running my 13,500 BTU ac on my 15 amp circuit on a 100 foot extension cord.
lugoismad is offline   Reply With Quote
Old 09-17-2016, 10:03 PM   #7
Dazed & Confused
M&K Hoffman's Avatar
Yes, when plugged in with fridge running and converter keeping battery charged I see an average of 3 amps draw.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 09-18-2016, 08:55 AM   #8
Oaklevel's Avatar
You will. It is hard on the compressor running low voltage
1966 Mustang GT
1986 Mustang SVO
Old 09-18-2016, 08:59 AM   #9
davel1971's Avatar
No doubt. Lots of voltage lost through that long of a small cord. Just because it's running now doesn't mean it's OK.
David & Lynn
Old 09-18-2016, 09:10 AM   #10
SeaDog's Avatar
One thing I have not seen mentioned is yes your house current will supply power to run the converter to charge the batteries provided your (if you have it) battery disconnect is in the connected position.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
power
