Old 04-02-2013, 09:12 AM   #1
Okay to jump start TV from battery
on your camper? I had an occasion the other day where I did not shut the doors on our newly acquired F250 with supercab tightly and I guess the interior light was on all night and the battery got drained. I had to call a tow truck to get a jump start.
If this were to happen at a campground, is it okay to jump start a TV with an RV battery? RV batteries aren't designed for starting applications but would a one-time jump start hurt anything? If okay, all I'd need to do is have a set of jumper cables rather than a charger or one of those portable emergency battery packs.
I now know to fully shut the truck doors so this may never happen again...
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 04-02-2013, 09:25 AM   #2
Dave_Monica's Avatar
Sure it will work. May turn it over slowly as it wouldn't have the cold cranking amps of your truck battery. It'd be best that the camper is plugged into shorepower at the time.
Dave
Old 04-02-2013, 09:45 AM   #3
Dave
Would that not put an unduly heavy load on the converter? I would unhook from shorepower just to be safe.
Old 04-02-2013, 10:03 AM   #4
firephighter's Avatar
If the TV were in the position of towing the camper. One could simply plug the trailer lights plug in and let the converter charge the battery over a short period of time. If you had a moment to spare. It would not put a strain on the deep cycle battery of the camper at that rate.
Jason and Angeleck
2007 301 BHD
1999 2500 Suburban 454
firephighter is offline   Reply With Quote
Old 04-02-2013, 10:33 AM   #5
caper's Avatar
Unless your battery is a true deep cycle battery you could use it to jump start. Most RV batteries are marine batteries and do have a cold cranking rating.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-02-2013, 10:38 AM   #6
dmf564's Avatar
I would not do it with the battery hooked up to the TT at all. The wiring in the trailer is not designed for that kind of draw. As far as using that battery for a jump. If you have a gas engine then yeah a one time shot maybe alright but if you have a diesel don't even think about it.
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 04-02-2013, 10:51 AM   #7
jevanb's Avatar
Please explain?? Because I remove 1 battery when I take the truck to the track, so I can shed weigh. My diesel runs and starts just fine on 1 battery
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-02-2013, 11:18 AM   #8
I would think that the converter would go into boost mode and supply 14.4V (the max) to the battery. What would be the harm other than that?
Dave
Old 04-02-2013, 11:19 AM   #9
dmf564's Avatar
A deep cycle battery by design is made for long discharge of amperage at a slow rate. This is done with larger lead plates within the battery. A car battery has very thin plates within the cells. This allows for rapid discharge of amperage needed to turn over the motor. With the deep cycle, if your using it to start your diesel truck where the demand for the cold cranking amps is double of what a gas engine is, you run a serious risk of over drawing your battery and greatly shorting its life. Not only that, but you are not supplying the right amount of power to your starter. Yes it is starting and everything is what you think is fine, but your making your starter brushes work overtime by not giving the right amount of power to do its job. Which shortens the life of your starter.
I'll say this, if it works for you, fine. But there are risks when you use something for something other than its intended purpose.
Old 04-02-2013, 12:01 PM   #10
To answer dmf654, I would only connect directly to the RV battery terminals. If I had to, I would lift the RV battery out of the box to closer to the TV.
I vaguely seem to recall that if you discharge a battery too fast (like in jump starting) you can cause buckling of the internal plates and then you've damaged your battery. I am guessing that a quick jump to get the TV (gasoline) running should be fine?
Langley, BC
