Old 05-14-2015, 04:11 AM   #1
Onan 5500 gaz
Which is better regular gaz or high octane Cummins manual no instruction since some small engine runs better with low octane what do you run yours with?
2016 Spartan 1234X Trail-Air Pin Box...thermo windows...12 cu.ft frig....3 seasons patio door
2011 Ford F-250 Super Duty Power Stroke King Ranch 4X4 diesel
Pierre Allard is offline   Reply With Quote
Old 05-14-2015, 07:39 AM   #2
Jerry01's Avatar
Imo all the "toys" should only be ran on premium fuel. And I always put Stabil in as well because I never know when it's going to get used again. Same applies to all of the garage gear. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 05-14-2015, 07:51 AM   #3
7 Year Class A RV'er
I always use the standard 87 fuel in everything - no premium needed. Used it in our last MH that had an Onan 4000 in it and use it in our golf cart without any problems. The Stabil is important depending on how quickly you'll deplete the tank, but more important is making sure to start and run it at least once a month to get the standing fuel out of the bowl. The ethanol in the gas will start to build up a residue (looks sort of like white salt crusted on everything) quickly, especially in hot humid weather. I stupidly forgot to start our generator once for about 4 months and wound up having to replace the $300 carb due to the ethanol.
2015 Legacy SR340 360RB
Old 05-14-2015, 05:08 PM   #4
f5moab's Avatar
I have converted to premium, non-ethanol fuel for all my small engines, Honda Gen, lawnmower, snowblower, weed wacker and using Sea Foam.
Trailer: Lifted 228BH, heavy duty springs and Yokohama tires
f5moab is online now   Reply With Quote
Old 05-14-2015, 05:16 PM   #5
Kilday4's Avatar
I agree that a fuel stabilizer and regular starting is a must. As to octane I normally run 87 in everything. Staying away from ethanol blended fuels is a must in my book for small engines.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
