Old 07-15-2013, 09:49 AM   #11
Do you have the model number for that pump? They list one that is good for 2 to 3. 5 psi.
cliff7122 is offline   Reply With Quote
Old 07-15-2013, 10:21 AM   #12
Fuel pump model number
Originally Posted by djorgensen3 View Post
Those generators are known to have a crappy fuel pump. I had to replace mine with a Mr.Gasket low pressure pump from Oreilly's. As soon as I put that on, it has run like a dream. Do not buy a factory fuel pump as it will have an issue too not long after you put it on. Also buy a can of Onan Decarbonizer spray and follow the instructions and it will clean up the pistons and combustion chambers nicely and it will run like a dream!
Replied to wrong thread. Do you have the model number of your Mr. Gasket fuel pump?
Old 07-27-2013, 06:38 PM   #13
could be the coil, thats what my generator is doing, starts up runs for few seconds then cuts off, I checked the spark after it quit, no spark.
2008 v-lite 30 wrls
gsbuick65 is offline   Reply With Quote
