Old 09-09-2013, 12:25 PM   #1
IHDRIDER00's Avatar
Onan BGE spec A No 12v To Fuel Pump
Hi, To be short. I have an Onan BGE spec A. It has been sitting for years. Cleaned Carb, Replaced Fuel Pump, ran fine. Went camping, it ran for about 4hrs. then started surging. Removed the load then turned off gen. The next morning it cranked fine but would not fire. Checking, I found no 12V to the Fuel Pump. Everything I've read points to the Control Board. Is there anything I can check before I replace the board? Thanks
IHDRIDER00 is offline   Reply With Quote
pump
