05-29-2019, 11:01 PM
Onan Generator running bad
We have an Onan quiet 4000 and it sat for some time. I think the fuel mucked up the carb. I could not get it to run originally, but I was able to open it up, spray carb cleaner in the component which sits in the float bowl (looked like an electronic jet system, and now it runs, but the idol is all over the place. I read online that we are unable to get a rebuild kit and now have to buy a whole new Carb. I am wondering if spending the $300+ for a new carb is what I should do or pay a company to fix it on their recommendation. Could it be something else? Never worked on an Onan Gen before.
Thx
26' Forrest Sierra Toy Hauler
26FBSP
Pulling toys for my boys!
05-29-2019, 11:02 PM
Thx
26FBSP
05-30-2019, 12:54 AM
I would try a product called seafoam. Unhook your gas line and run off another small gass can mixed with the additive and see if It cleans it up.
05-30-2019, 04:15 AM
Carb
My experience with Onan 5500, I tried everything sometimes I thought I had generator fixed and it would die at the time I needed it. You didn't say how long it was sitting. They need to be run to keep carb clean. I would replace carb. My old carb would sound like it was stumbing, sprayed cleaner it would run good a bit then shut off 5-10 minutes later. When would put load on it would do the same thing.
Save your headaches change the carb. Easy to do.
Retired Air Force
Side Kick: Karma
Tipp City, Ohio
05-30-2019, 04:26 AM
The low speed/Idle jets are still plugged up. You need to either remove the carb and have it tank cleaned or replace it. In the future as somebody already pointed out keep the proper mixture of SeaFoam in your gas tank at all times, never forget, never forget. Run the gen at least 30 minutes a month.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
05-30-2019, 05:33 AM
Doesn't anyone use Sta-Bil in their fuel systems ? I mix it in a 3 gal can for my mower and snowblower. I put the mower away in the fall and it starts in the spring on the first or second pull. The snowblower starts on first or second pull in the winter. I don't drain gas anymore and have been doing this for 5 years now.
05-30-2019, 08:06 AM
Attachment 205918
Yep. I still use it in all my gas power tool tanks, and boat and atv, and tiller.
2018 Forester 3011 DS
05-30-2019, 12:33 PM
Yes. Pull and tank clean or replace. Only way to get the small passages clear.
05-30-2019, 12:39 PM
Yeah...I use it on all my stuff. I haven't had a carb gum up in anything since I stopped draining the gas and started using Sta-bil.
05-30-2019, 12:56 PM
Attachment 205918
That's the Iowa thought process in you Woldpaq. [emoji4] Same frame of mind for me. Use Sta-bil in everything and have the same results. Neighbor doesn't and he buys a new mower every 3-5 years. Mine is 17 years old.
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: ‘18 - 27, ‘19 - 27, ‘20 - 30, ‘21 - 49
05-30-2019, 01:32 PM
One quick check: How much fuel do you have on board? When tank is down to half or a quarter, possibly depending on how level, the line to the genny could be above the gas.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
05-30-2019, 03:43 PM
It sat for at least a 1/2 year without the Gen running. I pulled the Fuel line before the fuel pump/filter and ran gas mixed with sea-foam. No improvement.
Any recommendations on where the best place to buy a new carb is?
26FBSP
05-30-2019, 04:26 PM
Take that carb off, take it apart and give a good cleaning.
05-30-2019, 08:26 PM
My experience was with an Onan 5500. Similar symptoms to others above - replaced the carburetor and solved the problem. Less than a year later, couldn’t get genset started, and after much research, replaced a faulty fuel pump. Learned the lesson on the carburetor - run that generator at least once a month.
Keith B
2016 Cardinal 3250 RL
2009 Ford F-350 DRW
06-01-2019, 11:34 AM
Attachment 205918
Same here. I also use supreme gas on all small engines. It's the ethanol in regular fuel that gums up carbs.
2017 FR3 28 DS
06-01-2019, 01:06 PM
No need to run Premium fuel, just put 1oz of Seafoam for every gallon of regular gas and will not have a gummed up carb. Seafoam will clean the the carbon off the piston as it burns through as well. Sta-bil does nothing for your engine.
Retired 2020.
06-01-2019, 01:18 PM
x100 on the seafoam . mix up a strong mix of the seafoam with the gas and let it run .May take a good 30 mins of run time to start cleaning up the carb . just went thru this with a friends mower . after about 30 mins it now runs and starts like new .
06-01-2019, 02:25 PM
Thirty would be a minimum to me.
Seafoam is the best “snake oil” ever made. There is no telling how many million$ that stuff has saved...yes I sold it for 20 years.
2017 Puma 297RLSS
06-01-2019, 04:13 PM
Just as confused as you
Carbs have gummed up on regular and supreme gasoline long before ethanol was added. As the gas ages the combustible compounds evaporate and leaves a less volatile liquid behind. If left long enough it changes to a sticky substance before drying completely. Any antique car guy will tell you that.
Richard & Jill
06-01-2019, 04:16 PM
Yes and now because of ethanol it happens twice as fast
