Old 08-09-2013, 09:33 AM   #1
IHDRIDER00's Avatar
Onan inastall question
Hi All, I have a 04 All American Sport 5th Wheel, 36CK Toy Hauler. Set up for a Gen. I have a 4000 Watt Onan that I want to install in the RV. Does anyone have this setup? Advice? Pics.? My main concern is how it sits, mounts in the RV. Any help would be great. Thanks
IHDRIDER00 is offline   Reply With Quote
Old 08-13-2013, 10:57 AM   #2
What model is it? I had a 4500 and have a bunch of manuals for it on PDF and some include install
Acableguy06 is offline   Reply With Quote
Old 08-13-2013, 11:00 AM   #3
I am sorry they do not have the install, I thought they did.
Old 08-13-2013, 11:04 AM   #4
IHDRIDER00's Avatar
Thanks, 4000 Emerald 1. Not sure of the yr. I don't have the model # with me right now.
Old 08-13-2013, 11:11 AM   #5
This should be your manual here:
http://www.cumminsonan.com/www/pdf/manuals/965-0528.pdf
In re to installing it it should be oriented with the start panel facing you. Is this the original set to the trailer or a replacement?
Old 08-13-2013, 12:10 PM   #6
IHDRIDER00's Avatar
I was told by a RV mechanic who inspected the unit for me, before I bought it. That it was set up for a Gen. It has a metal box on the street side of the pass thru storage area with a junction box mounted up on one of the side walls with a 30 amp breaker in it. The wires go from that box to a compartment where the RV 30amp power cord is located. There is a 30amp receptacle box there where you can plug in the power cable. The compartment door has a screen in it, covered by a panel now that can be removed. The floor in the box I think is plywood covered by a rubber flooring. My main concern is how to mount the Onan. Do I just mount it in the box? Cut out the bottom flooring for the venting? Should the venting be taken to the bottom of the RV? The bottom of the box is above the lower edge of the RVs side panel by maybe 2ft. I can handle the exhaust. I was going to use a portable marine type fuel system. We won't be using the Gen. much. Planning on a few NASCAR Races. Thanks
Old 08-13-2013, 12:28 PM   #7
Do you have a pic of the compartment you are mounting it in?
Old 08-16-2013, 09:54 AM   #8
IHDRIDER00's Avatar
Here you go.
Name:	RV GEN BOX 4.jpg
ID:	37882   Click image for larger version
Name:	RV GEN BOX 2.jpg
ID:	37883   Click image for larger version
Name:	RV GEN BOX 1.jpg
ID:	37884   Click image for larger version
Name:	RV GEN BOX 3.jpg
