Old 05-20-2015, 11:34 AM   #21
If you want a better battery than a group 27 try a group 31, I am running model # 31DC130 made by Crown Battery has a amp rating of 130. Crown Battery is the OEM for Cubcar and are a good Trojan battery replacement.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 05-20-2015, 11:55 AM   #22
2 group 24's. Trailer only came with 1 group 27, but I had these 2 old 24's, s I added the new box (white) then made an extension for the vent out of the PVC pipe. We hardly ever plug into power. Have a Honda 3000, and will hook up solar panels when I get a new shed built. Even thinking about a wind turbin also.
No where close to any hook ups.
Tim Myers
2013 Ford F-450
2015 Sabre 34 REQS-6
2018 XLR Boost 27QRB
dustym is offline   Reply With Quote
Old 06-16-2015, 09:54 AM   #23
Don't be fooled into thinking your tv will charge your battery...it only supplies a trickle charge at best unless you have a large gage wire running from your alternator to your plug. A #12 wire just won't do it.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 06-16-2015, 10:35 AM   #24
f5moab's Avatar
My Silverado does a great job of charging my batteries. I can run them down to about 60 percent and on a four hour drive, they can be charged back to full. That's traveling with the headlights on which increases the output to the trailer. Not sure of the wire size, but it is a 30A fused circuit.
The wire to and from the batteries to the converter is only 12 gauge.
f5moab is offline   Reply With Quote
Old 06-16-2015, 05:55 PM   #25
re: charging while towing.
I'm not sure about other trucks, but my Chevy 1500HD and my GMC 2500HD both bump up the voltage a bit when tow/haul mode is engaged.
On some vehicles that do not have tow/haul mode the voltage can be bumped up by turning on the headlights.
Read your owner's manual.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 06-16-2015, 08:09 PM   #26
f5moab's Avatar
Very true on both my 2013 and 2015 Silverado 1500...
From the owner's manual
If charging a remote (non-vehicle)
battery, press the Tow/Haul Mode
button, if equipped, at the end of the
shift lever. This will boost the
vehicle system voltage and properly
charge the battery. If the trailer is
too light for Tow/Haul Mode, or the
vehicle is not equipped with Tow/
Haul, turn on the headlamps as a
second way to boost the vehicle
system and charge the battery.
I use the headlights since my popup is too light for tow haul. And the I believe the lights on the trailer make it easier to see, even in daylight...
Old 06-17-2015, 04:49 PM   #27
mzbrandi's Avatar
Ok, just gotta ask. Does anybody know if the headlight on for more electricity works on a 2012 Jeep Wrangler?
mzbrandi is offline   Reply With Quote
Old 06-17-2015, 04:56 PM   #28
f5moab's Avatar
It should (or I would hope) be in the owner's manual. On my GM vehicles it was always under towing information.
battery
