Old 06-05-2017, 10:16 PM   #21
m35a2's Avatar
Originally Posted by A32Deuce View Post
Thermostat is 12 volt, that could cause it not to start.
Good point! I didn't consider the thermostat.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
m35a2 is offline   Reply With Quote
Old 06-05-2017, 10:33 PM   #22
Also check your emergency brake cable. If it pulled out and switched the brakes on, it will pull your voltage down.
2011 Traverse LT, 3.6L, FWD
Old 06-20-2017, 03:17 PM   #23
Got new PD4655V converter in this last weekend now lights are bright and 14.4 amps at battery. AC is still not coming on, ordered new AC start capacitor to see if that helps. I do believe the ac should still come on with shore power if the start capacitor is bad but I need one anyway being it checked out bad. May even go ahead and purchase an overload switch for the unit. I will update when new part comes in. Maybe this thread will help someone in the future.
scott_silverside is offline   Reply With Quote
Old 07-03-2017, 10:43 PM   #24
Install a hard start kit at
A/C, this is a secondary capacitor added to assist the main start capacitor.
mfMcFroggierPod is offline   Reply With Quote
Old 07-04-2017, 12:39 PM   #25
Update on AC and DC convertor. Replaced convertor and all works good except compressor on AC not coming on. Ordered new Start compacitor and installed and still no compressor working. I am wondering if thermostat could be bad and not sending volts to start compressor or if would have anything to do with that due to fan motor coming on. Any suggestions?
Old 07-04-2017, 12:44 PM   #26
Well...since you replaced the cap, put a voltmeter on the contactor and see if the thermostat is asking for cool...trace the 110 VAC on the unit to the compressor. Probably a problem with the contactor, but could be the thermostat.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 07-04-2017, 01:00 PM   #27
I replaced the Dometic Thermostat (analog) last year at this time with another one just like the original. I now have no high/low fan and the compressor is not coming on. I can deal with the fan not having H/L and I checked the voltage at the cool terminal and its reading 8.5 volts while the furnace is a full 12 volts. I find this strange. Can I replace with a digital from Walmart? I know the H/L fan will not work but again I can deal with that. Thanks
Old 07-04-2017, 09:45 PM   #28
Bypass the thermostat to test.
Old 07-05-2017, 12:15 PM   #29
not sure I am qualified to attempt that... I am taking it to a HVAC man this weekend and let him make an analyse of the situation. I will post back and let everyone know what the problem was and maybe it can help someone in the future
Old 07-10-2017, 08:57 PM   #30
7335: is this a 35 amp converter? I would upgrade to a 55 amp
Some items will work down to 10.5vdc
Large draw items will not.
The battery should be installed it absorbs the voltage spikes; this could possibly be what took out your converter.
Old 07-12-2017, 12:39 PM   #31
Actually I just noticed I put 7335 it is supposed to be 7355, its a 55 amp converter. I also discovered my problem with AC, it turns out its the control board. I have one ordered and should be back in business within a week or so. It takes awhile to get the part from CA. I also ordered a Honeywell Digital Thermostat to replace my analog. After reading some post that had demo's on how to DYI I figured I'd give it a try. I will post later when all is replaced.
battery, converter
