07-31-2017, 01:40 PM
Only kitchen power outlets working on 2005 26 foot sunseeker?
The only power outlet in unit working is the one above sink in gallery? None of the others are? But lights are all working throughout the coach?
07-31-2017, 03:27 PM
Shore power on? Check for a GFCI outlet that's tripped. Or if only on 12 volt, that outlet May be on an inverter.
07-31-2017, 03:34 PM
Are you connected to shore power?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-31-2017, 03:56 PM
Reset the breaker panel inside the coach. That did the trick! But the fridge only works for a bit, then check light comes back on. But nothing tripped on breaker panel or GFIs??? Faulty fuse maybe? Can you buy RV fuses at auto parts stores, home depot? Thanks again for the help
07-31-2017, 04:01 PM
Dometic reefer? If so and on auto mode, then that light will be on. On propane/gas switch, it will come on till it lights the gas side.
07-31-2017, 04:22 PM
Also furnance doesn't turn on. Thermostat in back of coach near bed. Switched from off to desired heat. Heard a click but furnace floor vents don't turn on. I assume that is a blower motor issue with furnance not GFI or fuse related?
Yes you can but RV a to fuses at any auto parts store. Just take a sample with you. Glad to help.
07-31-2017, 04:35 PM
They are 12 volt. You can check the fuse and use a volt meter to make sure its getting 12 volts.
07-31-2017, 06:29 PM
Is it possible you are trying to run fridge on gas? If the propane lines in the RV were discharged which can happen when you remove a tank to refill it can take a few tries for gas appliances to light. The fridge ( on gas) and the furnace will both go into safety lockout after a few tries. Reset b removing fuse wait a minute and reinstall fuse. Also if the propane lines were empty after filling a tank and you turn the tank valve on too fast, you can trigger the free flow prevention device and shut off the flow of propane. Check the switches on the fridge carefully they can be somewhat confusing. If you triggered the free flow valve, Close valve, Wait a few minutes then open very very slowly until you hear gas flow and stop wait a minute then open all the way.
TST Tire Monitors
2 100W solar panels
07-31-2017, 07:45 PM
Turn your propane off. Then turn back on slowly. After that's back on, go light one of the burners . Then try the reefer again. If everything is good, then it will come on.
07-31-2017, 08:04 PM
Dead house batteries?
2015 F-250 FX4
