Originally Posted by camaraderie
Just a (hopefully) final update for all those who chipped in with good advise...
After fully charging the batteries...I disconnected the negative and let them sit for 5 days and just re-measured the voltage after sitting and settling and the batts are at 12.7...100% full in static measurement.
I may have some loss of capacity from the single flattening...but it is certainly not anything to worry about.
Thanks again to all.
If it's been said before it's worth repeating. The fact you got on top of the problem immediately, and let the batteries charge fully, more likely than not most if not all of the sulfate formed by the discharge was converted and any loss of capacity would be in line with what most batteries loose from age alone.
The longer a battery sits in full discharge the more capacity is lost and in many cases it won't even accept a charge.
It would be interesting to see how all the cells compare when checked with a hydrometer. Also, how much life you get out of these batteries before you need to replace them based on meeting your power needs before they hit the 50% level. Expect to hear back on this in a few years
In my first years of boondocking I had a trailer with none of today's "Whiz-Bang" technology. 120 Volt lighting if you plugged in and a propane fueled gas lamp over the dinette table. Small 12 volt fixtures in bathroom and over each bunk. To charge the battery you plugged in a separate battery charger at home or if you were in a campground.
Back in those days I ran the battery down until the lights turned a dim orange color. Usually got a week or so from a group 27 Marine battery. It was good for 3-4 years.
Today we have fancy converter/"smart chargers", all lighting is 12 V LED, inverter to run the microwave, large battery banks, only run our batteries down to 50%, yet battery life seems to be the same 3-4 years. Go figure
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
