Mike Sokol, the guru of hot chassis condition, has a great article on open ground and how it "can" get worse with the appliances you use.
Are "Little" Shocks OK? | No~Shock~Zone
I copied part of it over, and hopefully Mike won't object. He is a participating member here, and helps out an awful lot. Here is an excerpt.
An RV chassis and skin with ANY significant voltage above earth potential (2 volts is max) is proof that you’ve lost your RV’s safety ground connection. Now, by itself an open ground connection won’t cause an RV hot-skin voltage condition, but nearly anything inside your RV plugged into its electrical system will cause some leakage current to the RV chassis-ground. And that leakage will show up as a hot-skin voltage of varying degree. The really dangerous thing is that sometimes those can be high-impedance leakage currents that aren’t particularly dangerous. And that’s when you feel a “little” shock. However, that same “little” current can quickly become low-impedance/high-current leakage in a heartbeat, and that will almost certainly kill you if you touch the RV with wet hands and feet. It’s just a matter of degree, and you never know what that degree is. So any feeling of shocks from your RV or appliance is a warning to turn off the circuit breakers and disconnect the power plug immediately.
If you do have a proper RV safety ground back to the service panel, then it should be impossible to develop more than 1 or 2 volts on your RV skin. It will harmlessly drain away the small currents from normal high-impedance appliance leakage, as well as trip the circuit breaker form huge currents that result from abnormal low-impedance leakage, such as a screw driven through a wire inside your wall.
So if you measure more than 2 volts between the earth and the chassis of your RV there’s a serious problem with your safety ground. This is usually as simple as a broken or loose ground contact on your extension cord or dog-bone adapter, but can also be due to a problem in your campsite pedestal or home power outlet. Old garages are especially dangerous since they can be ungrounded for years without you knowing it, and the first time you plug an RV into it there can be a deadly hot-skin condition. And certainly a worn RV pedestal outlet can have corrosion or loose contacts, and that can cause an RV hot-skin condition.
