Old 08-19-2013, 10:37 AM   #1
Outlet problems
I have a 2002 Forest River 23' Salem trailer. 4 of my indoor outlets and the outdoor outlet tend to only work part time. I can plug into then in the morning and they are fine. By 11:30 a.m., they all quit working. That leaves me with 2 working indoor outlets. I have checked fuses, breakers, and everything else I know. Any thoughts?
jfanuci is offline   Reply With Quote
Old 08-19-2013, 10:58 AM   #2
They are probably all on the same GFCI, and it's probably either defective or has a loose connection on it.
Old 08-19-2013, 10:59 AM   #3
Reset ground fault receptacle?
Good call Barry, you beat me to it.
Hudlow is offline   Reply With Quote
Old 08-19-2013, 02:45 PM   #4
It sounds like the outlets work sometimes, and other times they don't. Is that correct? They start working again without any intervention?
My first thought was the GFI as well, but I have never heard of a GFI tripping then resetting itself. I do agree the GFI must be checked, but it could also be a loose wire which feeds those outlets, and is much more serious. A loose wire can arc and start a fire.
SCOC is offline   Reply With Quote
