Old 11-18-2013, 11:41 PM   #1
Midwestgirl's Avatar
Outlets!
I'm wondering why my IPAD and cell charger connections become hot with 2 outlets in our 5er and other outlets never. The small table between the swivel chairs has an outlet on each side of table. When either item mentioned above are plugged in the side of the table the connection becomes hot. This doesn't happen if they are plugged in under cupboards. Thanks!
Midwestgirl
2005 K-2500 Silverado 8.1L 6 speed Allison
Midwestgirl is offline   Reply With Quote
Old 11-19-2013, 02:41 AM   #2
Engineer of Crazy Train
ChooChooMan74's Avatar
Do you have a DMM (Digital Multi-Meter)? I would see what voltage you're getting at those outlets. That could cause the power adapter to worker harder to produce the voltage required for your device.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 11-19-2013, 04:40 AM   #3
Suggest unhooking from shore power and pull the outlets and inspect for loose connections. If the wires are just pushed into the outlets, pull them out and reconnect using the screw connections.
Old 11-19-2013, 06:18 AM   #4
X2
I hate the push in connectors on outlets.
Filthy Beast is offline   Reply With Quote
Old 11-19-2013, 06:40 AM   #5
Thank you. Obviously I'm not an electrician but will find someone to do this. I know enough that it doesn't seem right to almost burn your fingers pulling out an IPAD or cell! Thanks again.
Midwestgirl
Old 11-19-2013, 07:37 AM   #6
rskrbina's Avatar
What OldCoot said. Loose electrical connections cause heat. Please find someone to check it out ASAP.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 11-21-2013, 11:41 AM   #7
rskrbina's Avatar
Was the problem with the hot receptacle's resolved?
If so, what was it?
Rudy and Jenny
Old 11-21-2013, 04:24 PM   #8
Hi this is how you can fix yourself.
Disconnect shore power
Remove plate from receptacle (if there are no screws it will pop off if you place a screw driver behind plate and pull out on it, top and bottom)
Remover receptacle from outlet box. If there is no box they are flip wings that attach to wall board.
Look for any loose wires. (If it was the kind with no box then you will have to snap the receptacle apart, clips on side of receptacle)
If you have any burn or hot spots the receptacle will need to be replaced. Receptacles installed in boxes can be found at a local Lowes or home depot. If it is the type that has no box they can be found at a camper store or and mobile home service company.
Reinstall receptacle, problem should be solved.
Hope this helps
Robert Whitlow Licensed NC Electrical Contractor
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 11-21-2013, 04:40 PM   #9
Ford Idaho's Avatar
Agreed, have all of the outlets checked.
Old 11-22-2013, 11:21 PM   #10
We are now in Laughlin for about 6 weeks and I will have a family member look at the outlet during their visit. I'm NOT using the outlets that give off heat. Will update as soon as this is completed. Wondering if poor wiring/defective wiring is common with new RV'S? Or did I buy a lemon? Our Keystone and Jayco TT were perfect in every way and we never encountered such problems in all the years we owned them. Contemplating trading it off now...after our trip.
Midwestgirl
