Old 09-11-2013, 03:13 PM   #1
scotturner's Avatar
Outside security light
My security light on the right side of my 5er has not worked in years. I bought a new bulb nothing so I tested it and there is no power going to it. I have a security light on the left side and of course that one works. I checked the fuses and they are all good. I pulled the fixture to see what the wires looked like and of course somewhere they change because they are not the same at the switch, so how is one to chase wires when they change them somewhere along the way? Where do I do from here? Any help would be great. Thanks
2006 CR Dodge RAM, EFI live from anarchy diesel, BD Tanny, BD inter cooler, Jake break
2005 All American sport toy hauler
scotturner is offline   Reply With Quote
Old 09-11-2013, 03:55 PM   #2
TURBS's Avatar
I assume you have power on both sides of the switch when turned on?
Turbs
Old 09-11-2013, 04:26 PM   #3
To chase the wires you need to make sure that ALL power is removed. You can then use an extra length of with and an ohm meter. Disconnect the suspect wire at both ends, attach the extra length of wire to one side and drag the other side close enough to the other end and check continuity.
Filthy Beast is offline   Reply With Quote
Old 09-11-2013, 04:35 PM   #4
scotturner's Avatar
I will check both I am pretty sure I have power at the switch it has three switches on it one for inside lights and the other two are for both security lights.
Old 09-11-2013, 04:45 PM   #5
Witch Doctor's Avatar
Check the ground if you have power at the switch.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-11-2013, 04:51 PM   #6
get a tick tracer. You put the transmitter on one end and then take the probe and start looking. when you find the end the probe will emit a tone. We use them all the time in the hvac control world
Poppy Bill is offline   Reply With Quote
Old 09-11-2013, 05:10 PM   #7
scotturner's Avatar
Ok and where do I find a tick tracer and are they $$$
Old 09-11-2013, 05:21 PM   #8
Home Depot, Lowes and maybe Harbor freight. les than $100
Old 09-11-2013, 05:27 PM   #9
scotturner's Avatar
Thanks Harbor freight $23.99
light
