03-11-2018, 09:21 PM
Overhead bunk won't lower
Bunk won't lower, get 4 flashing red lights between each green flash. Looked for fuse as indicated in previous posts, next to house battery, but could not fid fuse. Don't know if it is a fuse since I am getting power to panel.
Have 2018 Pursuit 32WC
03-11-2018, 10:20 PM
Between this and your other post about your water pump not working I'd say you have a larger electrical issue going on. Are you plugged in to shore power? Are other 12v accessories working?
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
03-12-2018, 10:38 AM
Getting 12 volts at switch, slides are working. Plugged into shore pwr.
03-12-2018, 11:27 AM
That's really odd, wish I could be more help. Did anything change between when they last worked and now? Battery disconnected and reconnected, etc?
2013 Shamrock 21SS
03-12-2018, 01:21 PM
I am sure they disconnected the batteries, the slide was not working. But other than that, the pump and bed were working when I dropped it off. I am setting up a time to take it back, should be under warranty.
03-12-2018, 01:25 PM
I would think there's polarity protection in the converter, but who knows what would really happen if someone accidentally reversed the wires when reconnecting the battery initially? That's not something I've had the desire to test. Something had to have happened to cause you multiple electrical issues/failures, though.
Good luck and hopefully it's a quick and easy fix!
2013 Shamrock 21SS
07-19-2018, 07:01 PM
In line with the bunk not going down... does anybody know where the Bunk Control Lift Box is located in a 2014 Coachmen Pursuit? I need to disconnect to reset according to Lippert’s recommendation, but I can’t find that unit.
07-19-2018, 08:24 PM
Certified Curmudgeon
Your error code “C” indicates you have one of 5 issues.
2 are reverse polarity so they are out. That leaves 1. Loose Connector, 2. Low Voltage (12.0 may qualify as low voltage) and 3. A bad motor (#1). You need a diagnostic. Good news that it is only 1 hr labor to replace a motor. Bad news is the motor is about $400.
Good Luck
Mike Dropped
07-19-2018, 08:26 PM
Maybe... Look behind the passenger side speaker in the panel above the dashboard.
Mike Dropped
07-20-2018, 11:02 AM
Update... The Bed Moves!
Thanks for the comments and feedback by others. I was able to work with Lippert and Coachmen - Plant 310, to get the information on how to reset and reprogram the stops for the Bed Lift. Everything works and 'Harvey' is back on the road again this afternoon!
07-20-2018, 11:34 AM
Thats great but the stop settings are not on the control box. They are on the back of the control panel. i.e. not what you asked. Also, you’re not the OP so your post subject might make folks think the OP has resolved his issue which is not the case.
Mike Dropped
