Old 04-21-2016, 11:29 AM   #1
overhead lights delay before lighting
Hello All,
2015 Salem Cruise Lite 195BH
So one of my overhead lights is messing up (bathroom light)... you flick the switch, and it takes anywhere from 1 to 10 seconds before it turns on. Kinda strange!
It is one of the standard double-bulb, 12V, built-in switch light fixtures I see in so many campers with the original incandescent bulbs. Once on, it stays on and is normal brightness. I don't hear or see anything unusual. There is no condensation in the lenses at all. We are hooked up to shore power.
Anyone had this problem?
s10texan
s10texan is offline   Reply With Quote
Old 04-21-2016, 12:07 PM   #2
Try changing the bulb
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-21-2016, 04:30 PM   #3
Try taking the bulbs out and clean the contacts the best you can (bulb and fixture).
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 04-21-2016, 05:32 PM   #4
Well I took the fixture down, wiggled the wires, and now it works. Must have been a loose wire. Aggravating, because I don't know which connector was bad. Oh well!
s10texan
Old 04-21-2016, 05:42 PM   #5
Flybob's Avatar
Could be just some corrosion on the connection or contacts as the bathroom probably sees more humidity than other parts of the rig. Might try a light coat of anti-oxidizing compound on bulb/socket.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 04-21-2016, 06:33 PM   #6
Forbes's Avatar
Connection problem some where or it could be you have a battery that has some slow electrons and they are playing with you. LOL
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-85 and counting
Forbes is offline   Reply With Quote
Old 09-13-2016, 08:27 PM   #7
Well its a late update, but it was the switch in the fixture that was bad. Replaced it and no more issues.
s10texan
light
