Old 01-10-2016, 09:09 PM   #1
Paralax Series 7400 Model 7455 help
I have a 2008 Cardinal 39RKS. The other day I parked it and emptied the water filter and I found the 30amp plastic fuse and fuse holder melted on my converter. I am sure I will need to replace the Paralax Series 7400 model 7455 but it is now obsolete. Question 1, What do I need to look for as a possible cause of the problem. Question 2, Any advise on the best replacement for this now obsolete converter.
thanks in advance.
dml352 is offline   Reply With Quote
Old 01-19-2016, 03:00 PM   #2
waiter21's Avatar
I upgraded my 2001 Mirada converter (7345) with a new 4 stage converter.
Two benefits of the multistage -
1) When I apply shore power (or generator) the converter kicks into high gear and charges the battery fast. We recently did this when we were camped out in the desert for a few days near Buckeye AZ
2) When I'm plugged into shore power for a long time, the converter kicks into low gear and doesn't boil the battery.
Upgrading converter to 4 stage | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
modifications
